How Many Tilers Own A Copy Of British Standards Literature?
Is the poll anonomous? I'm wondering if guys will answer truthfully if people can see who voted what.
I've read them. own none though. I couldn't recite the ad verbatim, but after over 35 years working them I think I'm entitled to put my own regional slant/accent on them 🙂
Nah public.
Got nothing to hide.
Now private
If you don't own a copy because it's expensive. Say so! Plenty of others will.
To be honest we find manufacturers have them and make products to their specs.
Tilers then stick to their terms and instructions of the adhesive and grout and tile and substrate manufacturers.
So there's no shame in saying you've never read a single page.
I haven't. I've read loads of quotes. But I don't know if they're making it up or what. I can't check what people are saying when they quote BS most of the time.
Be honest with the answers.
I bet only some of the big firms we have say they have some of them, not all mind.
how much does a full set cost?
They are all available through the BS website and last time I looked over £100 for part 1 and you'll need parts 1-5 (BS5385) plus all the other relevant ones so you can check the substrates are prepared correctly; general building bits (BS8000 I think);etc,etc.
I've never owned a set but have been able to access them at home through my local library - now stopped so I'd have to go into the library and use their (our!) computer to do the same. (I haven't taken part in the survey as I am no longer tiling).
My opinion of the BS5385 is that most of the parts could be incorporated into one as it is so repetitive anyway, but obviously less £ to be made from those who need a copy! Much of the text is also not very clear and written poorly and I think it would help everone (tradesmen and people checking what should be/has been done) if the tiling standard was started again rather than kept being updated every x years.
Ive seen bits, dont own any because it costs too much, which is ridiculas. Do TTA members get members get free access to them?
Can everybody access them at a library? Do all library's have them or what?
At the library they are accessed on the computers (if the library is large enough to have them and there is one free). The librarian will put in the code so that the BS can be accessed (this is the case in Worcestershire (well it was last time I went). You are then free to read the BS's but you cant print them so take a note book. Some library services may still give you to access on your home PC if you are a member - this used top be the case in Worcestershire but was then stopped. In the olden days before PC's the bigger library's had printed copies which were much easier to read and they would do you copies for a small sum - a much better system where public information was accessible to the public more easily.
Tiling Standards
Dan,
Dan,
Dan,
Dan,
