Discuss Electric Underfloor Heating Mat in the Tiling on Underfloor Heating area at TilersForums.com.
Ttt1601
Yea thts what I meant haven't actually crumched the numbers but I think in terms of cost to customer, there would really be no massive price difference either way, but I think vairo would work a bit cheaper, if you include labour and materials over all
A
Alzak
Can someone explain me purpose of this "uncoupling membrane" ?
My understanding was that on concrete you stick insulation boards with flexible adhesive and then heating mat covered with white flexible adhesive which you stick marble tiles on ?
Is this not correct process for tiling and underfloor heating ?
F
Flintstone
That is correct for porcelain tiles. With natural stone they are soft and aren't structurally stable as porcelain, as you will find out when a few probably fall in two!
The uncoupling is basically a layer which separates the tiles from the substrate, it alows some expansion and contraction in the floor without it transferring to the tile. There often made up of about 3 layers so can move independently
A
Alzak
Ah I see now I knew that stone tiles are not as hard as ceramic and that was the reason for using flexible tile adhesive so any movement in substrate would not transfer to tiles.
With this uncoupling membrane can you just lay this over heating mat or you need something between heating mat and membrane ? would membrane take the heat from heating mat without any issues ?
A
Alzak
That would be a problem as installation would be done by my Dad who would be flying in here from continental Europe for 2 weeks, saying this we have different approach to underfloor heating as is mainly (99%) water based systems so that’s why I need help on products from you guys.
He fitted tiles on 100s of floors with underfloor heating but not on wires… and his knowledge on local products is limited as well.
i agree, variopro would be more expensive, but when you weigh up the down time ect (your time) price doesnt work out that much more.
Lou
Admin
887
1,473
Staffordshire
Reply to Electric Underfloor Heating Mat in the Tiling on Underfloor Heating area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hi guys, Hope you are all having a fantastic Xmas. To cut a long story short I have installed...
I'm about to start on an upstairs wetroom. There will be wet underfloor heating going in via...
Hi. I'm after some advice. Need to screed above my underfloor heating pipes. Some rooms have...
Underfloor Heating Trending Threads
    Votes: 6 4.7%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.7%
    Votes: 16 12.4%
    Votes: 31 24.0%
    Votes: 3 2.3%
    Votes: 2 1.6%
    Votes: 19 14.7%
    Votes: 18 14.0%
    Votes: 15 11.6%
    Votes: 6 4.7%
    Votes: 3 2.3%
    Votes: 2 1.6%
