Discuss Durabase matting over Hardie 6mm floor in the America Tile Forum area at TilersForums.com.
Grazza
Points
68
Kent
Hi,
Would you use Durabase matting over Hardie 6mm floor?
Im not 100% happy with the ply floor so am going to use 6mm Hardie backer 1200 x 600 mm.
Its advised to go in a brick-bond staggered to reduce chance of cracking, but Im kind of thinking that there a loads more joins now than I had with the plyboard (which was two 18mm at 2400x1200)
On the floor Im using 1200 x 200mm tile - the plank wood effect, so I assume I'll need to ensure the joins are in the middle of the tile (100mm)
So Im wondering if I should use a decoupling matting over the Hardie 6mm floor to eliminate the chance of cracking? The ply is solid and flat just not good quality. I was gonna durabase over the ply so I have a roll already.
Cheers in advance !
Reply to Durabase matting over Hardie 6mm floor in the America Tile Forum area at TilersForums.com
