Discuss Caspari Antiqued Silver, how would you fix them? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
K
Kevbos
I know how I'd get on .porcelain was made to save money for manufacturers .and as you quoted all those old tiles now floating etc .have you retired a new build tiled in last 20 years .tiles fall off .grout badly dicoloured if not cracked or washed out .I fix Victorian mosaics for a living and to be competitive can only give 10 year guarantees as no adhesive can last much more than that outside .as opposed to doing it properly and it lasts 50 to 150 years .it's just getting silly with all the new products now .I know that times have changed and we got to move with them .but those times are changing because of greed and cost cutting.and not for ease of tiling and finished product .
In reply to how I'd fix them is just ring supplier and ask them. Get an email sent with what their specification is .and do that to the letter .then your covered
Just looked on web .you need to find out what type of resin is on back there is 3 types all need different types of adhesive Good luck.
K
Kevbos
Didn't tell me .but you did you were going to remove mesh that was put on for a reason. The tiles are weak they need the mesh .you need to find out what stuck the mesh then find right adhesive
J Sid
K
Kevbos
Lol I'm saying nothing I worked for one of the founders of the tta. Know how that all works
Oh and be careful when cutting a lot of the resin back tiles .the stone has silica in it which is not good for your health at all
N
NZ_Tiler
Sorry getting off the OP.
Porcelain saves manufacturer money?
The need more energy to fire at a higher temperature. I doubt they're cheaper to produce and it's reflected at the tile shops.
They're produced because of their superior properties.
Lou
Admin
1,473
Staffordshire
Reply to Caspari Antiqued Silver, how would you fix them? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
