Discuss Bringing a bathroom floor with UFH level in the UK Tiling Forum area at TilersForums.com.
F
felixfe
Hi there - Lots of interesting stuff about leveling compounds here (as well as everything else) but I can't seem to find the answer to my particular problem and wonder if anyone could help -
Most of my house has engineered oak boards at a height of 18mm laid over a concrete slab with wet UFH. For the bathroom, which measures approx 6 m2, however, I am planning on using either rubber tiles or slate.
So there will be a discrepancy of about 15mm between the rest of the flooring and the bathroom.
Just wondered how you would deal with this - screed over the top of existing slab to bring it level? use a leveling compound at this depth? leave it be?
Thanks so much for all the help here!
mikethetile
I take it you dont have an oak floor in your bathroom or its being taken up
you can use slc to bring the level up
im not sure where your getting 15mm difference
F
felixfe
Thanks for the reply - this is a completely new floor, so at the moment there is a level screed across the whole floor (comprising living room, kitchen and bathroom). The oak will be layed on top of this everywhere except the bathroom (since I have been discouraged from using a wood flooring in there), which is why I am left with the 15mm difference. Thanks for the tip, I will investigate it!
mikethetile
I was wondering about the oak in the bathroom areas
are you having ufh under the oak too
there will be less than 15mm difference in floor heights and this can easily be taken up with slc
F
felixfe
hi mike - yes, the rest of the floor will be 16mm engineered oak with a 2mm thermal underlay - so a total height of 18mm. I don't think the rubber tiles I'm thinking of laying in the bathroom come to much more than 3mm in height which is where the discrepancy is coming from.
The difficulty is in selecting a material to make up the height which won't undermine the effectiveness of the UFH - ie, by acting as a thermal block, rather than absorbing and maintaining the heat. perhaps a levelling compound will do the trick
thanks for your help
kilty55
Points
1,113
edinburgh
ive not had much experience with wet ufh mostly mats,but wouldnt thermal insulation boards which are used for the electric mats be of any use to 1.raise your height and 2.keep and distribute the heat evenly,i would like to hear other tilers opinions on this
Reply to Bringing a bathroom floor with UFH level in the UK Tiling Forum area at TilersForums.com
