Discuss bathroom job any advice, tips, tricks appreciated in the DIY Tiling Forum area at TilersForums.com.
Points
98
Yorkshire
Bathrrom getting ripoed out everything except the bath with two internal walls and two external.
Plan is to rip out old tiles,take wallpaper off plus any plaster left behind it and board all walls with marmox multiboards and seal joints on boards around bath area with their waterproof tape.
What size boards would you recomend since i dont know what the studs are centred at? E.g marmox 10mm centred every 300mm and 12.5mm is at 400mm.is this a big deal or should i have studs already bought incase of need to sister studs together to match the size but also to get the studs plumb and flat as possible??? =S
Solid walls dot and dab plus mechanical fixings.the floor looks like some sort of fake tiles maybe stuck down with floorboards underneath. Whats best to use on floor in this situation marmox or a cement board or a decoupling membrane like dural yellow one for ease of mind of no cracks tranfering through??.
Bathroom.wals 15sqm and floor about 5 and tiles are ceramic wall and floor
Walss 25 x 50cm
Floor - 45 x 45cm
Looking forward to hearing on any advice or tips i should know or methods i should consider. Many thanks
Points
98
Yorkshire
No not a comple rip out before but will be having a builder along side me who has and will be concentrating on plumbing/elecrrical side plus worktop while.i concentrate on the tiling.
Fairley new to tiling have done a ukprotiling course and have done a few odd jobs here and there for friends.
This jobs for a family member of mine so is willing to give me the experience to take job on alongside builder who has done these rip outs but with plasterboard instead.hope that explains it mate .
Boggs
Points
1,118
Uk
As @JordanLincs says it’s very important to remove any deflection from the bathroom floor.
This is especially important when using ceramic tiles on the floor.
An easy way to test the deflection is to fill a glass to the top with water, place it in the centre of the floor and jump up and down.
If the water spills over the edge there’s too much deflection.
If this is the case I would be looking to remove the entire floor and bracing between joists at 300mm centres.
Also I would recommend overboarding with 6mm Hardie backer board glued, screwed and joints taped.
And as @jcrtiling says builders should not be touching the electrics ;)
Any queries give us a shout.
Points
298
Lincolnshire
Also I would recommend 6mm Hardie backer board glued, screwed and joints taped.
6mm direct to the joists!?
Boggs
Points
1,118
Uk
Sorry, my previous post edited. :)
Points
98
Yorkshire
@jcrtiling if it was left to the builder it wouldve been tiled statight to the plywood :rolleyes:
@JordanLincs what instance would you use sometging like a ditra or dural does it not protect aginst deflection? Is it better used on say concrete floors?
@Boggs this is first floor job so want to use the easiest material to work with regardless of price they say xps foam boards are easier to cut and lighter but im not sure if its rigid enough for floor. Like to hear your thoughts on marmox/jackoboard on floors. But if its not the corect material to use in this instance then id go for the one thats right. Thanks for the tip about how to check for deflection :cool:
is therr a diffrence between deflection and lateral movement ? Sory for novice questions still tryna wrap my head around certain things
Cheers
Points
298
Lincolnshire
Cheers
Big floors, tiling on multiple types of subfloor. It's used to protect from lateral movement not deflection.
Reply to bathroom job any advice, tips, tricks appreciated in the DIY Tiling Forum area at TilersForums.com
