Discuss Tiling exterior doorway wall in the UK Tiling Forum area at TilersForums.com.
ajek
Points
36
London
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would prefer not to use ready mix adhesive but looking for a good alternative solution if any only due to buying a very large bag of adhesive powder which will go to waste. I would appreciate any thoughts on ready mix and brands if anyone has experience with long term longevity of the tiles staying put. The area although a small external wall is sheltered but not the cold.
ajek
Points
36
London
Thanks for your reply. I thought that would be the answer. Just a shame you can’t buy small bags cement based adhesive.
ajek
Points
36
London
What’s the background wall surface and what’s the body of the tile made of?
It’s a plastered wall that is painted. I was thinking about either fixing some tile backer boards, prime and tile. The other option is to remove any loose plaster, score, prime and tile.
TimelessJohn
Subscribed
Points
73
North East England
Whichever you do make sure all paint removed (unless mechanical fixing of backer boards).
As per Dave - you can get a smaller bag of cement based adhesives.
Reply to Tiling exterior doorway wall in the UK Tiling Forum area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
