Discuss Faulty or defective adhesive in the DIY Tiling Forum area at TilersForums.com.
38
Woking
I’ve just had my bathroom renovated by a chap recommended by my neighbour.Firstly he quoted by day abs said it would take 10 days! It took 22 so labour cost was £4000I’ve had him come back because the floor tiles are moving and grout cracked. He re grouted using silicone
Now a tile has fallen off the window frame. He has used dot and dab method. He is adamant that the tile adhesive I got from the tile warehouse with the tiles must be defective.
He has used dot and dab onto plasterboard even In The shower. Should I be worried about how waterproof my shower will be. Is it likely to be faulty adhesive. Not sure if I should just get someone else to redo this
38
Woking
He is at fault , totally wrong fixing method. As for 22 days. Wow
would you advise re tiling the whole bathroom?
He is convinced it’s not the dot and dab but the adhesive itself. He’s co rodent that the shower will be fine. Obviously I’m worried it will go badly in the future. He was very offended that I suggested it was his workmanship. As for the 22 days. That was to plumb abs til the whole bathroom and move the door. It’s a 2mx2m bathroom, shower only. It’s seemed to take forever
Dave
Subscribed
1,000,000
Co.Durham
His fixing method does not comply with BS5385. Personally looking at the window head where the tile fell off , he’s hardly even attempted to get coverage. So if the rest of the room is the same then it could be a risky chance you take.
38
Woking
Thanks. This is what I feared
bsc ceramics
Subscribed
548
worthing west sussex
I would be very worried about having a shower if i was you.
His methold of fixing is wrong and as said above does not comply with
any standards.
Sorry but it all needs to come off and be re done.
Now the hard part is trying to get your money back.
22 days is maddness, iv known houses build quicker than that...
Unless he holds his hands up it looks like a court battle, but it all
points to being in your favour.
Keep us posted and let us know how you get on
38
Woking
He will not admit that it’s not acceptable. He’s blaming the adhesive, the fact that the plasterboard was uneven ( he replaced all the boards)
He got very upset and said I was calling him a cowboy. He left without repairing it and said he won’t be fixing it in the next two weeks. I’ve paid him £3500 of the £4540 he invoiced.
He did my neighbours bathroom and had to come back because a floor tile cracked. He’s working for another 2 people in our close at the moment. He’s bad mouthing me to them saying I’m just causing trouble. I’ve decided I will just get another tiler to redo the floor and window. Thanks for your input
Dave
Subscribed
1,000,000
Co.Durham
Go show your neighbours in your close what he does. His methods are wrong and a tike falling off shows just that. so if he say’s the adhesive is at fault , then is he saying the whole bathroom will fail because the adhesive is faulty. ?
Ajax123
1,213
Lincolnshire
it looks like real live rogue trader stuff. He will presumably be doing the same to your neighbours.
Adhesives are very rarely "defective". theres not uch to go wrong. Get the adhesive rep to pop out and have a look. he/she will confirm where teh fault lies for you.
Trigger
483
uk
Hi
Firstly, before I get abused I would like to agree with all of the comments above. It has not been done correctly and it is very unlikey that there is a fault with the adhesive. If you can find out the manufacturer of the adhesive I am sure that a sample can be tested to see if it is at fault (I know this can be done with plaster, never needed to try it with tile adhesive). If they can confirm the adhesive is not at fault it will work in favour if you intend to pursue it.
Here is the unpopular bit, having looked closely at the picture I suspect the reason it has failed is down to dust on the back of the tile causing it not to bond and not the fact that it has been dabbed. I think you can see the white dust stuck in the adhesive.
The fact that it has been dot and dabbed does not necessarily mean the rest of it will fail (although no one can guarantee that). I have taken many many tiles up over the years thats have been dot and dabbed and they showed no sign of failing. The only way those tiles were coming off was with a hammer and chisel.
Good luck getting it resolved.
Reply to Faulty or defective adhesive in the DIY Tiling Forum area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
