Discuss Loose external porcelain tile in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
36
farnborough
I got some everscape porcelain tile from Topp Tiles last year installed externally. It was put on a bed of mortar and a few of them has now come loose. These are the ones that lips just over a few mm over steps down hence the movement. Others seem ok as they are pretty heavy.
How best can I stick them down to the hardened mortar without digging everything up? I have about 7 slabs that goes across the steps.
They are pretty heavy 60cmx60 format. I also have easy joint resin grout in between.
Thanks!
Dave
Subscribed
1,000,000
Co.Durham
They have been fixed down wrongly , sand and cement isn’t suitable for external with porcelain and they will simply pop up with the freeze/thaw we have in the winter.. a screed mix with a slurry bonding of the tile to get a bond..
36
farnborough
Hi Dave - im new to this so excuse the naivety. When you say screed mix and slurry bonding agent, does this mean, I can apply some cement levelling screed on top of the mortar then some SBR onto the tile?
Im trying to avoid digging up the hardened mortar. Will an adhesive do?
Dave
Subscribed
1,000,000
Co.Durham
A quick fix would be tile adhesive , i was just stating the initial install was not done correctly for Porcelain tiles..
Reply to Loose external porcelain tile in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Sticky
