Discuss outside corner in rectangle bathroom in the DIY Tiling Forum area at TilersForums.com.
mr angry
i will mix a small amount each time before i tile due to me being a novice. what primer should i get...the weber pr360 or something else?
cheers
Waluigi
Don’t forget to clean your bucket and tools between mixes otherwise the next mix will set much quicker than it should.
So much easier with a slow setting adhesive. I suppose at least you got a good deal though.......
Boggs
1,118
Uk
I wanted to try that but nobody stocks it near me.
I buy direct from Tilemaster but you have to have it by the pallet.
I have used many adhesives in the past but find this one of the nicest to use and is the best blend of price/performance.
I use their Ultimate adhesive on floors, but you have to be really clean as you go, it’s sticks to everything and is a pain to get off when set!
mr angry
@Waluigi
it was either the weber or the 7 tubs of bal white star plus. i was sure that the majority of folk here wouldve picked the 3 bags of weber stuff at £20.
i cant find a local supplier of the weber 360 but i can get the bal primer 1kg for £9.99 out of topps tiles is this ok to mix with weber?
Boggs
1,118
Uk
@Waluigi
That will do the job just fine.
mr angry
i cant get to topps right now but can goto b&q later. can i use the mapei plaster primer £9 b&q?
cheers
Boggs
1,118
Uk
cheers
Yep.
Whatever you use the result will be better than the other 3 walls with nothing on and pre mixed addy.
Reply to outside corner in rectangle bathroom in the DIY Tiling Forum area at TilersForums.com
