Discuss Failure! in the DIY Tiling Forum area at TilersForums.com.
I would think you could disconnect ufh from central heating at ufh manifold and do a pressure test on ufh . Another option could be come the summer when u are not using ufh shut the valves at the ufh manifold and if pressure doesn't drop on heating system that should give you a pretty good indication .
423
N. Ireland
Boiler man came and looked today, replaced the prv it was leaking some water onto the vessel and replaced another part ( unsure if this was leaking!, I wasn't there so I'm hearing second hand info from my mum!)
Boiler guy reckons this has been the cause of the pressure drop but to monitor it. What it has been using over the 4/6 weeks he thinks would maybe be a cup of water so very little.
He doesn't think there is a leak in the floor as pressure drop is so small, no visible sign of water on floor/ up walls, heating is working perfectly.
His opinion is the floor has lifted because of the poor tiling job which is of course is definitely correct! Just still seems strange how it lasted so long then tented so badly in a straight line over a period of approx 2 weeks.
So! Monitor now and hopefully this will put an end to topping up the boiler every 4/6 weeks
SJPurdy
Just reviewed the pics. It looks to me that the different coloured adhesives are from different periods i.e. floor originally tiled with the lighter (white) adhesive and then retiled with darker adhesive (maybe even over a grey SLC). That should not be a problem however looking at the pics of the partly taken up tiles there seems to me to be very little joint spacing between the tiles (the grout is clinging into the radiuses on the edge of the tiles and the thin joint in between. This could part of the reason for the failure - the tiles have very little compressible grout between then to absorb some of the stresses due to eg. thermal movement . They have held out for the 12 years and then maybe some additional stress occurred which caused the tiles to tent. When the tiles are relayed make sure there is minimum 3mm gap for grout between them.
Dan
Admin
1,318
Staffordshire, UK
Reply to Failure! in the DIY Tiling Forum area at TilersForums.com
I'm Looking For This Tile Porcelanosa Town White Polish 595mm
I'm looking for a few Porcelanosa Town White Polish / Pulido floor tiles - badly laid in my new...
