Discuss Tiling To Calcium Sulfate Based Screeds (Revised Dec 2011) in the Tiling on Underfloor Heating area at TilersForums.com.
Hi Ajax, I was trying to be 100% sure I was doing this right.
I have a calcium Sulfate new floor, laid 3 years now (long story) and I have cold UFH, that is pressurised but not hot yet.
I need to crack on and lay some 600x600 porcelain in one room and en suite so part of the house can be used before the rest is completed.
So what I need to know is:
Do I need a expansion gap after xM of continous run? If so what to use? This room through to en suite is 6m.
I have the mapi primer for calcium sulphate and the recommended mapi adhesive and grout. Is there any special requirement for 10mm porcelain laid on calcium sulphate, such as adhesive thickness, is a 5mm gapped trowel OK?
Thanks if you can help me.
Ajax123
1,213
Lincolnshire
These are general tiling questions and not to do with calcium sulphate. The UFH must be comissioned and run before tiling. The screed needs to be clean and free from loose friable material and needs to be absorbent. This means lightly abrading with a sander and vacuuming.
600x600 will need to be back buttered and grout gaps no less than 3mm. Maximum vay size for the tiles is 40m2 with max bay length of I beleive 8m butthat needs checking. Joints can fe either proprietary formers or dry jointed and siliconed with colour matched silicone.
The screed must be dry below 0.5% or 75%rh and should be tested so.
Not sure of trowel notch size but that will be set by the adhesive nit the screed.
Ajax123
1,213
Lincolnshire
The rules for underfloor heating are the same for all screeds. It should be cokussiobed and run. If you don’t you run the risk of thermal expansion cracking the screed and the tiles.
You say it’s had 3 years to dry… it’s also had 3 years to get wet again.
The heating should run through its commissioning cycle and then switched off for 48 hours before moisture testing. assuming it’s dry and clean tiling can then commence
Given the type of primer and adhesive you have selected there is no room for cutting corners.
Ajax123
1,213
Lincolnshire
If your screed is going to crack it will do so when you first run the heating. Do you want the tiles to be in place of this happens.
How do you know it to be dry…. You don’t. Floors do funny things especially when fluctuations in temperature occur. You can get cold spots and dew points. Running the heating also eliminates these.
Nothing wrong with Mapei but as I say no room for cutting corners.
OK, I see your point about cracking, I may have to chance this one room then.
I don't suspect any odd differences in the floor, I helped at all stages and insulation and membrane were all 100%. The house is triple glazed with Velfac windows, never seen even a hint of condensation so I hope that will be OK.
Now to find a method of cleaning the floor without water, I ground the utility floor with a grinder and vaccum attachment but what a faff! May look for a broom like a patio weeder steel brush...
Any ideas?
Reply to Tiling To Calcium Sulfate Based Screeds (Revised Dec 2011) in the Tiling on Underfloor Heating area at TilersForums.com
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
