Discuss Kickboards in the Tiling on Underfloor Heating area at TilersForums.com.
Dave
Staff member
Subscribed
389,894
1,000,000
Co.Durham
No not under units the kitchen was in place before tiling so could only tile to feet of units. So wondered as cable close to an exposed edge heat could be escaping out the side of tile, yes floor is heating up ok, issue is where kickboards are not as warm as rest of floor.
Why would they want kickboards to heat up ?
E
EdinTiler
@Paul2468 Nothing much you can do if it's an insulation issue other than accept it unless you, in the great words of Orange Juice 'Rip it up and start again'.
I pretty much refuse to fit ufh without the appropriate insulation boards because of what you are experiencing now Paul. Apparently a minimum of 70% of rising heat is lost when no insulation is used. Especially on a concrete floor.
EdinTiler
Well that is what client is asking to rip it up, and re do it. The builder supplied materials we just fitted what was given to us, so dont know where that leaves us really. Builder seems to think we are responsible even though we just fitted what was supplied
Is he expecting u to replace everything?
UFH, tiles and labour?
First thing I'd be doing is talking to Schluter!
Spare Tool
Does actually state on the schluter website it doesn't need insulation boards
I think u should get schluters take on the problem.
If they say u have a correct installation minus the boards, ie u've left the cable back from the kickboards the correct distance and that it is usual for a decline in temp at that point on the floor then u'll have an arguement!
The insulation board wouldn't make a difference to the heat dropping off at the edges as far as I can see.
It'll just take longer to come up to temp.
The heat will radiate a certain distance from the cable, so if each cable let's say radiates heat over 50mm, then beyond that it will cool, so at 75mm the edge will be cooler.
On the other hand, if they say u can take cable up to edge of kick boards,
Then u may have a problem.
As far as builder taking responsibility, well you're the Proffesional floor layer, he is not!
I would imagine that in a legal situation, u'd be the one held accountable because you're the Proffesional.
Pretty much in the same way a disclaimer written by u and signed by a client for u to cut corners isn't worth the paper it's printed on.
Lou
Admin
Staff member
1,473
Staffordshire
Reply to Kickboards in the Tiling on Underfloor Heating area at TilersForums.com
  • Sticky
Hi All, We are looking for a tiler for potential tiling work in the Suffolk and Essex area. We are also looking for anyone who is interested to do a tiling apprenticeship with us. Anyone...
  • Question
  • Question
Hi all. Just wanting some advice and wondering what the pros in here are using nowadays for cutting large format porc? Ive been relatively lucky up until recently and been able to cut most of...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
