Discuss Need advice. How do I raise the level of just one tile? See picture. in the America Tile Forum area at TilersForums.com.
36
Australia
I didn't tile this old bathroom but I'm cleaning it up, one tile is missing and needs to be almost half an inch forward to match the tiles around it. Can I use extra adhesive? Or extra cement? Or something else like mortar? I really need to get this fixed. Any tips would be appreciated.
ed.
36
Australia
Please contribute to this thread if you have any new information or can even just reiterate what has been said already. :)
Hey Malcolm
Yes, you can use extra adhesive, just make sure you prime the surface.
Hi, would it be better to fill that entire space with a 1/2 inch of adhesive and press a tile into it? Or should you start with the adhesive a bit more in the middle of the tile and press it in until you get level with the other tiles?
Basically what would be the best way to apply it and get the amount and height right? I have quite a few similarly set old tiles that I really should start replacing and could use some advice to do this neatly. Thank you.
258
Guernsey
Thanks. Should I layer it and let the first layer dry? Or just use half an inch of adhesive in one application?
Yes you could layer it.
Reply to Need advice. How do I raise the level of just one tile? See picture. in the America Tile Forum area at TilersForums.com
