Discuss Limestone flagstones - Price for laying in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Ttt1601
I don't know Norcros adhesives, and I'm never likely to, but in my experience the maximum bed depth of an adhesive will relate to small isolated areas and not the whole install.
It could well be cheaper to use a board or latex to make up the deficit.
I'd probably go with latex, to obtain a perfectly level substrate.
Completely agree with @3_fall plus with heavy stone, bulking out 10mm of addy you would undoubtedly result in some slumping issues as it dries
SJPurdy
Cost of laying will also to an extent vary with the size and type of limestone flags. Larger pieces are a two man job to lift and position them. Some limestone I have laid has been flat finish so that the finished floor is flat like a supermarket floor. Other limestone has been more rustic (riven surface edges not flush with each other etc.) and requires more adjustments in the thickness of the adhesive.
Gentlemen,
Thanks again for your advice.
The Limestone size is 600mm x 900mm tumbled edges and tumbled surface, so definitely not smooth. I've uploaded a photo of the flagstones. The photo shows exactly how I would like the finished look.
I phoned two tilers today and am beginning to get the feeling that not too many tilers have experience of laying 20-22mm thick Limestone flagstones?
Lou
Admin
1,473
Staffordshire
Reply to Limestone flagstones - Price for laying in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
