Discuss Layout in the Canada Tile Advice area at TilersForums.com.
Points
36
Bristol
So just laying out some white Metro and the window is ever so slightly offset, do I 1. Have a small piece beside the window or 2. Work out from the window and hide e a short tile behind the tap. Will be using light grey grout.
eddcottee
Points
493
Ipswich
If you mean you are wanting to center the window, you can either have the grout line in line with the center of the window, or you could have the centre of a tile in line with the center of the window. Does that make sense / help at all? Might be enough to give you a better cut a the window edge (moving everything half a tile across)
Reply to Layout in the Canada Tile Advice area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
