Discuss Grinding / Polishing / Small chips in the DIY Tiling Forum area at TilersForums.com.
Julian 'Farmer' Bonsall
Hello
When cutting ceramics with my table saw (Wet Saw, 180mm disc, MARCRIST DIAMOND TILE BLADE from screwfix) I get some small chipping to the glaze. On a recent kitchen I moved to cutting almost all tiles with a grinder as it was much quicker (using either a ck850 or Protilers blade) but there are still small marks on the glaze. I used the side of the cutting edge to remove the very small amount of tile to remove this unwanted edge.
I noticed on the forum various grinding pads and wondered if a set would be useful for my toolbox. I was looking at something like this :
Sigma Diamond Grinding Pads (multiple grits available) | Buy Sigma Tile Cutters Online from Pro Tiler Tools - https://www.*******************/product/sigma-diamond-grinding-pads--multiple-grits-available-
Concrete guy
What you linked to are dry diamond polishing pads. Designed predominantly for polishing granite and other hard stones. The key word here is "polishing".
You'd be better of buying some electroplated diamond hand pads, many of the tilers on this forum use them, either ours or bought from eBay or from Protiler tools. They all do the same thing.
(I can't post links it breaches the advertising rules of the forum - but they are easy enough to find).
Even if you did feel like setting yourself up with some polishing pads for a mechanical polisher. For what you guys do (tilers that is ) you'd be hard pushed to better Silicon Carbide discs. Mainly because they work on pretty much everything you're going to come across and it's only small volumes of edges you're ever going to be polishing.
The advantage of diamonds really kicks in with volume. If you're polishing hundreds of linear meters of product on a daily basis then it makes a lot of sense. That said you'd have pads for marble, pads for granite, pads for quartz and pads for porcelain.
So the average tiler (and I know there are a lot of tilers here that are above average!) will do everything they need to do with some hand pads and silicon carbide discs (if they have the need to invest in a polisher).
Concrete guy
Note for the more "experienced" ;) members of the forum that Silicon Carbide is also known as Carborundum.
So you may have come across solid black rubbing blocks of this stuff for all sorts of uses. Mainly they were used for cleaning tools but they work equally well tidying the edges of tiles up.
It's pretty much the hardest thing available bar Diamond.
ATS - thanks for your reply thats very helpful. I've posted a photo of what I think you mean. What I have tried to use is some 400 Grade Wet and Dry (also Si Carbide) from my playing with car paint work. It was just a little slow and being a paper not suited to tile edges.
Is there any type of grinder option available (I have never used the blocks) or, even if there is, any point to one? (i.e. is the hand block quick?). At the moment I run two grinders and pop the cut tile onto the second one with a cheaper disc in it just to take the cut edge off, but its really far to aggressive.
So really a solution for the cut edges of a glazed tile. (Electroplated Diamond Polishing Grinding discs - ATS Diamond Tools - https://www.atsdiamondtools.co.uk/product/electroplated-diamond-polishing-grinding-discs/) (115mm Electroplated Diamond Grinding Disc - ATS Diamond Tools - https://www.atsdiamondtools.co.uk/product/115mm-electroplated-diamond-grinding-disc/).
I can see a tool that is rigid is needed for my needs but not at all sure quite how aggressive the tool needs to be.
Concrete guy
I have to tread carefully here Julian as I'm not a forum sponsor.
The hand pads pictured above are ideal for tilers, they are quite rigid and ideal for tidying up edges of envelope cuts, that kind of thing.
The #50 is quite coarse. Most tilers are going to be using #100, #200 or #400 grit pads or a combination.
Velcro backed discs are a stonemason/concrete product, basically a version of the hand pad that can be attached to a polisher. You'd be using that on thick edges (20mm/30mm) or surfaces and as such are a bit aggressive for ceramic and porcelain tiles.
The electroplated grinding discs we brought in due to demand from tilers. They are #120 grit and a general purpose tidying/finishing tool.
It's also worth noting that the grit numbers for silicon carbide and diamond are not algined.
Diamond pads run generally from 50-3000 grits, above that they are variations of buffing pads, 5000 grit and such.
Silicon Carbide run from #36 (extremely coarse) to #1200 (used by glaziers for polishing glass).
So a #400 Silicon Carbide isn't grinding, it's polishing. As impish mentioned above, you'll need #60, #80 or #120 for shaping and light grinding. #120 probably being the most versatile and used SiC grit disc.
Concrete guy
Velour backed means it fits on a velcro type backer.
Plain back is just that, it's plain paper and you use a contact adhesive to glue the discs to a plain backer.
In anything other than a stone production factory environment, velour and a velcro backer make more sense.
ATS thats really helpful and useful information.
I wonder if the grades are similar to wet and dry paint finishing paper.
They sound like just what I could use in my battery grinder - really appreciated.
Reply to Grinding / Polishing / Small chips in the DIY Tiling Forum area at TilersForums.com
