Discuss Badly cracked limestone - can I replace individually with decoupling in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Kenco
Points
88
Lincolnshire
self build completed 10 years ago, large kitchen diner on 65mm hand mixed screed, with no stress relief joints & wet UFH!
Tiled with limestone, found that the tilers switched to cheaper adhesive not suitable for UFH approx a third of the way through the job, they then added flex fluid to the remaining adhesive! Was not happy at the time...
I have multiple cracks in the tiles, star shaped in places so likely stress cracks from the screed.
Of course if I knew what I knew now, I would have decoupled. But too late.
Can I replace the several cracked tiles and fit decoupling membrane to these individual (or groups) of tiles and potentially get away with it?
Taking up the tiles 70m2 and relaying would be an expensive nightmare, as kitted kitchen, skirtings etc...
As a final thought, would home insurance likely cover any of it? Or am I just wasting my time perusing this route?
I Am tempted to take it all up eventually and replace with floating engineered hardwood floor.
Example Photos attached...
3AAC92B1-A02D-4724-B3C0-8D8B34B20DF6.jpeg 36C0B5E4-3729-4703-8A6E-16B1C33F01E3.jpeg E4A42154-BAAA-48A1-9683-F86E11481C00.jpeg
widler
Points
1,328
England
Like Paul says , it’s only going to get worse,in another 5 years, you will have probably lifted 90% of the floor and re fit if that’s the way you want to go.
Trav is extreamly brittle , and will crack if you look at it .
I’m going to get ripped for this on here, not bothered like;)
I tiled over a 60/70m2 trav floor, badly cracked after about 10years, much much worse than that.
I used TM matting and tiled with 1200x600 4.8mm porcalthin tiles, still there and solid as a rock weeks later:sunglasses:
J Sid
I wouldn't lift any as would expect the screed to be failing as well.
clean out all the cracks with a suitable cleaner, Lithofin power clean, wet vac out dirt, leave to dry and resin fill cracks and polish back. live with it till you want a new floor.
lesson learnt the hard way....
Kenco
Points
88
Lincolnshire
Wow... fast responses so far
Yes painful and expensive lesson learnt.
I cannot tile on top of the existing tiles as there would be too many height transitions to other surfaces (carpet in lounge and the remaining tiling that appears ok leading to the hall and utility.
I bought some coloured resin last year, and as suggested will probably see how that looks on the more severe cracks.
I used 2 different tilers when I built my house, they both were 2nd rate having looked back. Wish I had known about this forum beforehand...
J Sid
buy a colour to add to the clear resin.
insurance claim, all I can say is don't ring up and ask as this is then on there records and your premium will go up even if you don't claim or they say no.
if you screeded this floor by hand , one mix at a time this was probably imho the start of your problems.
Kenco
Points
88
Lincolnshire
Hmmm, I rang the insurance last year, renewed since and it didn’t seem to go up, so maybe got lucky.
Yes, if I had my time again I would use liquid screed, stress joints, decoupling membrane without fail.
Just a shame ‘tradesmen’ are not aware of the risks when advising & doing the work.
I won’t even go into my 2 bathrooms that have cracked due to tiling straight on board, I even called a adhesive company at the time and they said it would be ok. They were wrong!
Dumbo
Fair enough you saying about tradesmen but what we are up against most of the time that once the client has bought the tiles they think that's the big part of the money spent , then when you tell them labour costs , material costs and then start on about things like membranes and movement joints they like to think are they really necessary and can we leave that part of the job out .
Kenco
Points
88
Lincolnshire
I totally agree with you.
I don’t envy you guys because to do the job PROPERLY is expensive.
Proper suitable sub floor
Correct drying technique
Quality adhesives/grouts
Decoupling membrane
Quality sealant
Skilled fitting
It becomes very apparent that the tiles are a small fraction of the actual overall cost...
Reply to Badly cracked limestone - can I replace individually with decoupling in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
