Discuss Efflorescence issue in the Australia area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi! Hoping for some advice on fixing this efflorescence. Only have this issue in the shower. Have the same tiles elsewhere without issue. Have tried vinegar, have tried dravco tile cleaner and have tried 12% hydrogen peroxide. Each one has made no change. Each one gave a good scrub with.
Tile Marble Granite
Hi! Hoping for some advice on fixing this efflorescence. Only have this issue in the shower. Have the same tiles elsewhere without issue. Have tried vinegar, have tried dravco tile cleaner and have tried 12% hydrogen peroxide. Each one has made no change. Each one gave a good scrub with. View attachment 134371
Try to scrape a small portion with a Stanley blade, see how it goes.
Dan
Admin
We have some good threads on this use the forum search. I'm just finishing off this blog and am off to sleep. Will be back in about 9 hours (I'm also on school run).
Is that grouted ? If it is that needs to be re grouted as there is many holes in the joints that will lead too a failed floor especially on a wet tray floor. As for the residue go too a tile shop and buy some tile acid let it sit on the affected areas then wash off.
Reply to Efflorescence issue in the Australia area at TilersForums.com
mcgtech
