Discuss what weight tiles will paramount take in the Canada Tile Advice area at TilersForums.com.
Eddy66
38
South Yorkshire
Hi Guys, another newbie here, what weight in kgs per sqm will honeycomb plasterboard walls take please? Paramount Partition wall boards type. I want to fully tile my bathroom walls in 600x300 ceramic tiles but, since finding out the wall structure I am now concerned the walls won’t take the weight - help please.
Eddy66
38
South Yorkshire
Yes they are, currently half tiled with 6x6 bog standard ceramic tiles with white emulsion walls. The existing tiles are dropping off and the plaster underneath looks like new (24 year old house). I thought take the existing off, make good if required, Unibond all walls, use Mapei waterproof paint for where the shower over bath will be and then add the new 600x300 ceramic tiles. My main concern is the weight on the paramount walls (new to me) though I see what you may be getting at, as I suppose the skim could break away under the weight? Thank you for your time.
Albert
1,253
Gateshead NE8, UK
The reason Dave is asking if they are skimmed is because skimmed boards will take less
weight than unskimmed
Eddy66
38
South Yorkshire
Hi Albert, thank you for your response, i’ve done a bit more digging and found that plasterboard walls that are not skimmed will take 32kg/sqm whereas skimmed ones will only take 20kg/sqm. I reckon the tiles i want with an allowance for adhesive and grout come in at 21.5kg/sqm - i suspect that these figures will have a tolerance built in simply to cover themselves - so i think 21.5 may well be ok? My main concern is more about the capabilities of the Paramount panels as opposed to stud walls or dot and dab on to masonry. I think i’ll have a look at the skim on my paramount walls and see how well adhered it is - might be worth removing it to expose the board and simply go with the 32kg/sqm most of the advisory sites are saying. Gents, thank you both for your responses.
Boggs
1,118
Uk
I would just leave the skim as is and follow Dave’s advise, if you start trying to remove the skim chances are you will damage the paper face of the plasterboard weakening the bond you have available at the moment.
Paramount board is difficult to repair, if it’s too far gone it really means removing it completely.
CJ
1,088
Somerset
I have paramount boards in my place. (Egg box walls) and found it no Problem, as long as the plaster skim is sound, you should have no problem 👍
Eddy66
38
South Yorkshire
Hi Boggs, good advice - i’ll leave as is then, thank you.
Hi Dave, i’ll have a few taps around the walls to see if the bond is still ok - just had visions of the lot coming down and landing on me in the bath - never come across paramount before, what an odd thing - apparently is was developed in the 70’s as a low cost solution to aid in the building of council properties. Thanks everyone for your comments.
Boggs
1,118
Uk
Even odder is the straw version!
Reply to what weight tiles will paramount take in the Canada Tile Advice area at TilersForums.com
