Discuss Tile Straight Onto This? in the DIY Tiling Forum area at TilersForums.com.
H
hmtiling
Do you use s2 on top of durabase? I'm sure that defeats the object of the membrane as it's too deformable
J Sid
Good to know Tilemaster as come up with a product the sticks to substrates where other can't and fixes tiles where only none water based adhesive are recommend by the tile manufacturers.
So how do we stand if we fixed say Gulf Stone with Tilemaster S2 ultimate and there is a failure ?
323
Lincoln
Like any other get in touch with Tilemaster & their Technical department, Like I say Ask them, They Spec S2 ultimate for tiling Quartz, composite, Bitumen, Steel/metal, Green screed. Everything, and yes I use S2 on top of Dural Matting. If in any doubt I always ask before a project
Again Great Service from a Family run business, I have had no issues.
J Sid
Thanks for that.... but that's your opinion, check the spec's & ask the technical guys...
surely they can't be wrong!
You maybe right, but how will you get on if the tile fails because you have not followed the tile manufacturers recommendations?
Will Tilemaster stand by you?
H
hmtiling
No offence but I'd go with the technical direction of Dural when fixing durabase and the technical direction of a tile manufacturer when fixing their tiles. S2 isn't the miracle answer to everything.
323
Lincoln
With Quartz I always ask where they have come from, They need good quality, you can use two -part Flexi Hardi backer, Liquid Grout..etc..but if they are cheap imitations, like I am sure you have seen Then There is still a Risk, Tiles curling at edges etc... Will the internet shop stand by thier tiles??/ No, They will always look for blame in fixing, I only do each job as if it were my own, I do not want comebacks,
I would recommend trying Tilemasters... or at least, get in touch, see for yourself...
Reply to Tile Straight Onto This? in the DIY Tiling Forum area at TilersForums.com
Hello I plan to tile our bathroom with 60x60 cm tiles (8 mm thick) and the shower (because of...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
