Discuss Tile Straight Onto This? in the DIY Tiling Forum area at TilersForums.com.
J Sid
Because I like living life on the edge :sunglasses:
Or because they over-specify to make sure that risks are minimised. I can minimise my own risks by understanding why a product is specified, and choose accordingly. It's not corner cutting - it's rationalising.
Living dangerously I would say. :(
323
Lincoln
After two days, I realized just now that tiles are quartz / resin and wooden support .......... sorry. is old
I would stick Dural Ci + Matting down with Tile Master Adhesive S2 Ultimate, Then S2 Ultimate For the Quartz & Grout in Kerakoll Liquid Grout.
Have no Problem with the floor then!!
U
Unused Account 1
You can tile onto it ,but if any problems ,when you lift the tiles ,you have to replace the floor,as it will bring half of the floor with it
H
hmtiling
Belt and braces but meant to be 2 part adhesive with quartz/resin and I don't think s2 is recommended with Durabase
J Sid
Why not use the adhesive recommend by the tile manufacturers?
I don't use Tilemaster, but is S2 Ultimate recommend for fix on waterproofed coated chipboard?
323
Lincoln
Yes No Problem Dural actually spec S2 to stick there matting down, but S1 is fine... And Tilemaster adhy S2 Is the choice for Quartz... absolutely no problem with this especially with underfloor heating
J Sid
So that's a yes to waterproofed chipboard is it?
And your happy using a water based adhesive on resin tiles? Against recommendations.
This Tilemaster looks like a miracle product will have to look into it and speak to them, will save a fortune in costs. ;)
323
Lincoln
Yes Yes & Yes... Yes speack to Tilemasters.. The S2 Ultimate is fantastic. use it all the time with Dural matting on timber ... its the Future, I have used many products over the 23 years in the Tiling Game ... this one fills me with confidence! great service as well...
Reply to Tile Straight Onto This? in the DIY Tiling Forum area at TilersForums.com
Hello I plan to tile our bathroom with 60x60 cm tiles (8 mm thick) and the shower (because of...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
