Discuss Buying black quartz starlight online in the Australia Tiling Forum area at TilersForums.com.
Concrete guy
More resin in the cheap stuff
This is a common misconception. The resin is the most expensive component of the make up of quartz, the factories do all they can to reduce this not increase it.
Most quartz will be between 7% and 15% resin, each manufacturer only has to produce a single colour at 93%/7% to state that as a make up of it's products.
The more pure the colour the higher resin content so pure white (which is also the most difficult to make) is 10%+ resin.
I used to be involved in the manufacture of quartz.
Silestone is the market leader in volume by brand, it's expensive.
Compac, Cimstone, Ceaserstone, Radianz (by Samsung) are amoung other well known brands.
Q
Qwerty
The more pure the colour the higher resin content so pure white (which is also the most difficult to make) 10%+ resin.
Interesting! Not what a lot of retailers are telling both the public and trade. Cheers for that.
Why does the cheap stuff curl then?
Concrete guy
As a product it's heat sensitive. I find any notion that it can be used with underfloor heating as fundamentally wrong.
I'll try and find a technical spec sheet from one of the manufacturers which provide a list of storage requirements. It's an eye opener.
From memory they include:-
Store inside only as the product is not frost proof, is sensitive to acid rain and UV exposure.
It will fade if left in direct sunlight.
If you left a slab of quartz on two tressles overnight, in the morning it will have sagged like a sheet of plasterboard.
When used as a kitchen worktop you can't place hot pans on the surface, they will simply melt it.
EDIT:- Here's a Ceaserstone fabricators PDF, read the storage and handling page, it's interesting.
Broken Link Removed
mit4d
Thanks again for the reply another brill job
Sorry for sounding thick but i have not bought a tile im life and im new to all of this.. what is tolerances? colour differences between tiles?
from the samples ive received the sample from tile mountain seems to be the deepest black colour, although the sample i received from stonesuperstore has the best fleck effect ... im stuck on what to do
how do these stores managed to sell at a cheaper price? is it just because these tiles are sort of budget style alternative to the makes mentioned by ATS and other users?
Im awaiting a sample from tilehq this week, they seem to get some good feedback on this forum along with very reasonable prices.. i might just go for it as its only for 7m2 kitchen and i dont want to be spending £80+ m2 as ive got other projects i need $$ for..
thanks again
gamma38
1,058
Bedford
Tolerances are the sizing, i.e. if they state a tile is 300 x 300 x 10mm the tolerance might be + or - 1mm or less. When i called tile mountain they told me there's is + or - 3mm on the 300 and + or - 6mm on the 600 x 300 granite. The thickness was shocking as well varying from 5mm to 14mm. It was like sorting and laying un-calibrated slate. Hope this makes sense. It can cost you a lot more to stick down bad quality tiles due to man hours etc so it's not always the purchase price that is the only factor.
Concrete guy
Don't buy from a small 100mm sample, use the sample to decide which shop you want to visit to view the product in larger form.
Small samples are a guide only and can sometimes be (unintentionally) misleading.
mit4d
Thanks again for the replys
Unofrutnatally i dont drive and all of these online shops are down south and im based up in newcastle
I cant see how they can legally sell a procudct without stating the above mentioned problems before dispatch?
14mm to 5mm if a huge difference in size! they sound like off cuts or somthing?
i might send a few messages to these shops to see if they can give me an honest reply with regards to their quality in tiles..
Out of the shops ive mentioned in my first post, who do you think would be the best or more reliable?
gamma38
1,058
Bedford
Ask them the tolerances before you buy and try and get them to send you something in writing to confirm there numbers. That way you are covered for that at least if they turn up wrong. That said i did get told that the laws for distance selling are a lot stricter than buying at your local shop.
Reply to Buying black quartz starlight online in the Australia Tiling Forum area at TilersForums.com
