- Reaction score
- 0
Hi, a few years ago we had an extension built and the tiler recommended by the builder did our bathroom. He wasn't the best.
Since then, the floor has been getting gradually looser, so I decided to take it up and redo it myself. We had electric ufh put in, then large porcelain tiles 600x600x10. The base of the floor is chipboard panels, as I said in a recently built extension, the electric ufh looks like a wire only (no mesh), it looks like he's stuck down the wire with bits of adhesive here and there, then tiled over that, but it looks more dot and dab than even everywhere. I'm pretty sure he used Bal flexible adhesive.
What do you think went wrong?
Im going to redo it, so assuming I can get it all up without damaging the wires (a big if), reading on here I should put I thin layer of slc on then use flexible adhesive evenly. I'm worried that it's the floor itself and it will happen again. I don't have a lot of space to play with so can't afford to put a layer of thick plywood down.
Advice greatly appreciated.
