Discuss What is the best substrate for Travatine wall tiles? in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jarmany
Hi,
I am planning to tile the walls and floors of my bathroom with travatine tiles, 406x406x12mm.
I am having to re-build some stud walls and wonder what is the best base board material for these tiles. I am a bit concerned about the weight of them all!
I guess the normal thing to use would be plasterboard (12.5mm?), but I wonder if I should be using plywood instead.
What advice can your members give? The walls will be tiled up to the ceiling (around 2.6m)
Thanks for your help
Nick
Dan
Admin
Staff member
Plasterboard can carry a fair weight. Actually more than plaster alone. Use plasterboard :D
Dan
Admin
Staff member
Just to add to this, I have in my head, 32 kg per square meter for plasterboard, might be worth double checking but I think your tiles shouldn't be heavier than that, although they will give you back ache when you're carrying them around the house etc.
Smiths
You're correct Admin, 20kg/m2 for plaster and 32kg/m2 for plasterboard.
UKTT Darren
TF Official Sponsor
Subscribed
Prime with Bal apd the wall, use a white cement based adhesive with a solid bed floor trowel. Make sure you seal the tiles before grouting.
Reply to What is the best substrate for Travatine wall tiles? in the UK Tiling Forum area at TilersForums.com
Dawz84
