TileFix Direct
This official sponsor may provide discounts for members
Discuss Wetroom vinyl replace with tiles in the Floor Advice - Flooring Forum area at TilersForums.com
Mapei Tile Adhesive - Official forum sponsor
Adey1980
Reactions
8,775 19
Caerphilly
hi all,
Just had a quick look on forum and couldn't find anything so here goes.
Just been to look at a job- ground floor wetroom for disabled/elderly, has a shower end with folding half height door.
Toilet, biddet and sink.
The floor is vinyl going to tiled wall and customer wants to replace the vinyl floor with tiles.
Customer says the shower will only be used on occasions as they will mainly use it for the toilet/sink.
Area is 6.5 metres square. The customer is supplying all materials etc and I suggested a plumber changes the round drain for one to match tiles.
Any tips/suggestions that I should look out for.
Many thanks for any help or advice
uHeat Official Forum Sponsor for Underfloor Heating (Electric and Wet)
Chalker
Reactions
631 1
Tadcaster
What's the floor construction? Will need, like you day replacing with a drain suitable for tiling. Will need lifting too.
The floor will need tanking. With it having vynil, the floor won't have defined lines for elvelope cutting. I would suggest mosaics to get over this. If they want bigger tiles you could screed the floor to get rid of the dish shape.
Adey1980
Reactions
8,775 19
Caerphilly
  • Thread Starter Thread Starter
  • #3
It is a ground floor and been told it is concrete underneath.
Adey1980
Reactions
8,775 19
Caerphilly
  • #4
Just had a thought, what if I was to suggest to tile the area around toilet/sink/biddet up to the wheelchair friendly door and leave the shower area as it is.
Would this work?
Spare Tool
Ah well that's different...yep be a lot less hassle to leave shower area alone then :)
Adey1980
Reactions
8,775 19
Caerphilly
  • #8
has anyone else tried this? Maybe might be worth telling customer it would be too expensive to tile etc?.
peteablard
Reactions
701 2
Cheshire
I think it would look a bit naff if you leave the vinyl. As mentioned above I'd mosaic the tray area or build the main floor up and around the outside of the tray and envelope larger tiles. Obviously that's after changing the drain
Adey1980
Reactions
8,775 19
Caerphilly
  • #12
1st question I'd ask is do they own the place - you say new owners but they may be altering a housing companies property.
They own it, I've messaged them to say I couldn't help them out.
Thanks for all the replies and advice guys
Reply to Wetroom vinyl replace with tiles in the Floor Advice - Flooring Forum area at TilersForums.com
Click here to support the forum/remove ads
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
