- Reaction score
- 16
Sorry. Calcium based https://www.tilersforums.com/forums/tile-adhesive/ is not for use WITH matting.Ultra standard set is
Underfloor Heating (UFH): If UFH is being installed it must be fully commissioned before starting the tile process to ensure it is in full working order. This includes both electric mat and water pipe systems. Once the UFH has been commissioned it can be set to a low level to provide a max floor temperature of 15 ̊C whilst the tile and grouting processes are undertaken. It is critical that this temperature is not exceeded as this can force dry the https://www.tilersforums.com/forums/tile-adhesive/ and grout with the potential of causing cracks in the installation or tiles to de-bond. Maintain this temperature for a minimum period of 7 days while the installation cures and hardens. After this time the UFH can be brought up to the required room temperature slowly at a rate of 5 ̊C per day.
From the technical data sheet ultra tile fix. Standard set is slow set! Calcium based https://www.tilersforums.com/forums/tile-adhesive/ is for use without matting. Your still walking on cobbles you northern gimp!
