TileFix Direct
This official sponsor may provide discounts for members
Discuss WATER OR ELECTRIC UNDERFLOOR HEATING - New Extension in the Tiling over Electric Underfloor Heating area at TilersForums.com
L
Letmein123
hi all,
I'm about to start a new extension which will be 27ft x 11ft (8ft ceilings) and will be an open plan living/kitchen/dining area. The floor will be ceramic/porcelain when finished.
My questions are the following;
If I opt for water underfloor heating, can this work on the same combi boiler as the rest of the house (2 bed bungalow, I will be installing a new boiler).
Given the size of the room, is underfloor heating enough on its own? Or do I need radiators
An alternative would be to have electric underfloor heating AND radiators which can operate independently (however I know the cost to run these is a little more) - what are the recommendations? Is this a better/safer/cheaper option?
Any general thoughts appreciated!
Lee
F
Flintstone
  • Thread Starter Thread Starter
  • #3
Water underfloor heating is more suitable if this is a new extension and it can be fitted into the screed, it will warm the space without radiators.
L
Letmein123
  • #4
You say you are installing the boiler yourself?
I'm not installing the boiler myself no, but having a new boiler installed. Just incase there are any specific requirements to the boiler
L
Letmein123
  • #5
And it will provide enough heat? Can it run on the same system as the radiators to the rest of the house?
F
Flintstone
  • #6
I don't know the ins and outs of it really, some on here do, perhaps @Uheat - Jake can advice.
But yes they will provide plenty of heat, and it's a nice warmth too as it's so well spread
Chalker
Reactions
635 1
Tadcaster
Wet ufh can heat just about any space. It will need a separate zone from your boiler. If it's a combi, it will need converting to two zones, as it works separately to your radiators.
Uheat are a sponsor on here and if you contact them with a room drawing, they will provide a quote and cad drawing.
If it's a new extension, make sure you can install it into a screed. This works best to transmit heat to the space.
N
NZ_Tiler
  • #9
Wet underfloor would be my choice as you can always change as to what heats the water...
Uheat - Jake
TF Official Sponsor
Reactions
146 1
Wet UFH sounds like the best option for your extension, this would act as a primary heating source and wouldn't need any extra source of heat either. If you're worried about the heatloss due to a lot of glass then we can close the pipe centers to 150mm to create a little more wattage per m2.
Feel free to give me a call on 01394 593305 and I'd be able to answer any further questions and prepare a quotation for you.
L
Letmein123
  • #11
Thanks Jake I may well do that
Reply to WATER OR ELECTRIC UNDERFLOOR HEATING - New Extension in the Tiling over Electric Underfloor Heating area at TilersForums.com
New Threads (Sitewide)
Mapei Tile Adhesive - Official forum sponsor
Top Bottom
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
