Discuss Warmup dcm pro heating in the Tiling on Underfloor Heating area at TilersForums. USA and UK Tiling Forum
Andy Tiler
I think with this system you have to self-level, unless i am
reading the instructions from your link wrong
After using hundreds of mtrs Albert i would prefer to self level over the matt. with levelling compounds now setting in 45 mins its a doddle.. if ever a tile needs changing and easier see your chalk lines when setting out
Bopster
Thread resurrection time lol
I installed loads of warmup before but not the mat system. Kitchen I’m doing in the new year will have this type of system over a concrete slab with porcelain tiles. Height increase will be critical, obviously 10mm insulation boards set in flexible https://www.tilersforums.com/forums/tile-adhesive/ on the primed slab would be better but will 6mm boards be enough? I’ll Slc ontop of mat before flex https://www.tilersforums.com/forums/tile-adhesive/ and tile
OP
Q
Qwerty
Why are you using SLC over the top rather than tile https://www.tilersforums.com/forums/tile-adhesive/? I know it can be done with SLC but interested to hear why. I'm assuming its the levels?
OP
F
Flintstone
I would just tile it in one without levelling whenever possible, I have done it both ways. I would only level if the floor needs it .
Bopster
Was going to be but doesn’t have to, just that used there products loads so familiar and trust
OP
F
Flintstone
Be carefull which boards you use under DCM pro as there can be issues with some of the more textured boards out there.
Bopster
Was going to us warmup 10mm as used them loads before. Like to keep all same manufacturer for ufh so if there an issue they got no issues
Reply to Warmup dcm pro heating in the Tiling on Underfloor Heating area at TilersForums.com
05jtaylor
I've Disabled AdBlock
