Tony Griffin
- Reaction score
- 1
Discuss Wall prep for tiling advice in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Most of it yes, had only shortly before removed tiles so still need to scrape some more off. This is where the bath was and the skim coat over the render was quite crumbly and practically fell off leaving the finish you see in the pic.Have you taken all of the loose finish plaster off
How much of the undercoat plaster is visible %
Thanks for the advice Wrighty. Is reskimming the walls the only way? Is this is the best option then so be it. Can l not just skim the areas that sit back of the render that is left behind? There must be a 3mm difference.Remove all the loose plaster seal all the walls with a mix of 3 parts water to 1 part unibond once dry apply a neat coat of unibond, this will leave a slight tack to the surface when dried then the whole room will need reskimming , this will need time to dry maybe a week before sealing with a quality acrylic tile primer 2 coats follow the manufacturers instructions good prep will give you a great finished job. Cheers kop
I was considering that, but it is a space issue yes. I may just do that wall as other walls have stayed sound after tiles have been taken off. Would you take it back to the brickwork and dot and dab straight onto that or would it need sealing first?Easier to just plasterboard ifyou have the room
You have not come across a perfectly skimmed room yet me and you are going to be having wordsI've not come come across a perfectly skimmed room yet.. Imo best way would be to either overboard as it is and mechanically fix through to brick, or knock the lot off and dot and dab plasterboard and take that opportunity to get everything flat and plumb..
You will no doubt be pushing your weight limits very close to or more than likely over recommended skim weight limits anyway.
Reply to Wall prep for tiling advice in the Canada area at TilersForums.com
