Discuss VIVA TILING - Sharon Taylor | Mosaic Specialist in North London in the Work Wanted for Wall and Floor Tile Fixers area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Dan
Admin
Staff member
I'll help with this in the week. :)
Edit: I've started on customising your listing for you. It's a nice one to make stand out. Can you check the new "Speciality" tab is okay? - And edit anything you think isn't quite right. I'm trying to find the female sparks and pipe monkey listings to cross-promote you all. But tilers has taken priority over the directories so I'll be able to pick those links up when I get to them whilst editing the listings there. Not sure if that's okay? Let me know. There's an electrical installation company that only employs female electricians. Caused a bit of a stir in a thread on there but they didn't half get noticed. :)
@MissTiler I could do with:-
  • Links to 3 job threads on the forum somewhere - I'm sure there are a few on here but haven't the time to search
  • 3 or 4 pictures of different work
Can you help me get those? :)
Then you're pretty much done. I'll waffle around the images and then hand the listing back and you can take it from there and sharpen anything up. :D
Also, let me know if you'd like me to change your forum username to Viva Tiling. It would change all your content and tag it under that new name. But then it'd appear when people search for Viva Tiling of course. Not sure if you'd rather keep the advice separate from the actual business of tiling.
(NB: I'll remove these discussion posts once we're done - then they're usually just used by fellow tilers to comment on your work as and when you add pictures to the thread - which helps keep the content fresh in search engines and the forum etc)
Reply to VIVA TILING - Sharon Taylor | Mosaic Specialist in North London in the Work Wanted for Wall and Floor Tile Fixers area at TilersForums.com
Finias Coroama
