Discuss Vinyl tile adhesive in the Floor Advice - Flooring Forum area at TilersForums.com
markster
Hi
I've taken up some old vinyl tiles on a screeded floor and the adhesive is as sticky as the day it was put down.
It's an amber colour and so not a bitumen based adhesive.
Can I lay porcelain tiles straight on top, or do I need to treat it somehow, or even use a solvent to remove it?
DHTiling
  • Thread Starter Thread Starter
  • #2
You can use a heat gun to soften it some more and scrape up the residue, then solvent to clean up any left residue.. what substrate is it.?
markster
  • #3
It's a sand cement screed.
I've read elsewhere of forum members recommending a primer?
markster
  • #5
I've got most of them up now.
With the exception of one or two which had quite a bit of adhesive, the majority have come up ok, leaving the screed a brown colour but without any residue which you can scrape off.
Is it still worth going over it with a solvent cleaner?
I guess the answer is it wouldn't hurt?
DHTiling
  • #6
You can now slurry coat or use a latex leveller to give a good bonding coat to tile to.
Reply to Vinyl tile adhesive in the Floor Advice - Flooring Forum area at TilersForums.com
New Threads (Sitewide)
Top Bottom
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
