• Thread starter Perfect Tiling
  • Start date
  • Replies 2
  • Views 1K
  • bal
Discuss Using BAL Flexbone in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
P
Perfect Tiling
Hi all....hope everyone keeping safe. I have a floor to tile in the next few weeks once the commissioning has completed its cycle.
Customer has purchased BAL flexbone which I have never used although I use other decoupling mats that are bonded to the floor.
What size and style of trowel do you guys tend to use....tiles are 600 x 600 x 10mm porcelain and I'll be using BAL rapid flex.
I always back butter as required but I take it you can't lift a tile to check coverage as the mat will just lift up since its not stuck down.
Cheers in advance.
Paulg83
Cheers in advance.
Never used flexbone but just pry the tile up gently with a bucket trowel or similar but don't be doing it with every single tile, a 12mm trowel and a flat floor and you're golden 👍
Reply to Using BAL Flexbone in the Adhesive and Grout area at TilersForums.com
Finias Coroama
