Discuss Use of ready-mix adhesive for shower wall in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hello, I’m so confused after reading numerous threads. We have a new build, and I’m doing this first bathroom from scratch by myself (pretty much). Ive never tiled. The shower area is barely started, I just bedded down the nassboard shower floor to the concrete screed, and the surrounding walls are marine ply. I have 6mm hardie board to put on the marine ply. I bought Everbuild Aquaseal Waterproof tanking membrane, which I had planned to paint over the hardie board (one it’s fastened in place, seams tapes, etc). Now I’m reading I cant use the Bostix Showerproof ready-mix adhesive on the walls for my 10 x 20mm metro tiles. Is this true? Should I not tank the hardie board? Should I tank the marine ply before I put up the hardie board? I have a ton of other questions, but I better just start with that. Thanks!
Dave
Use a slow setting cement based adhesive 👍
Tiberiu
Better use Wedi boards instead Hardie. They are totally waterproof and you only need to use their special adhesive sealant between the joints. No waterproofing paint and no tape required.
Reply to Use of ready-mix adhesive for shower wall in the Tanking and Wetrooms Forum area at TilersForums.com
Midland Commercial
