Discuss Underfloor heating probe in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Mike Chapman
Hi, underfloor heating not working think it's the probe which I can't access, is there an external probe I can use, if so how. Cheers
Tile Shop
The probe should be encased in a conduit down the wall and into the floor so that you can pull it through from the thermostat and replace it if it goes wrong. If it hasn't been channeled correctly, then you are going to struggle putting the new one in without lifting the tiles/flooring. Having an external probe, I can't imagine it would read the temps accurately.
CALLING @Uheat - Jake !
Spare Tool
You can set most thermostats to read the air temp instead of the floor, if its working when you do that its got to be a fault with the probe, as Paul said only way to repair is to lift the tile nearest the thermostat and put a new one in. Most ufheating suppliers used to supply conduit with there kits to insert the probe in but a lot don't any more..
R
Rookery
And even if you have a spare probe, they're a real pig to push another one through the conduit, down the wall and into its place.
Chalker
I generally use the conduit. But I would like to see somebody get another back in.
To the op.
How do you know it’s the probe? I would be testing the element first. The manufacturer will tell you the correct resistance readings.
macten
From what I understand (which ain't much to be fair) is most thermostats with a digital display (even the cheap ones) give out an Error code if the probe fails.
Uheat - Jake
TF Official Sponsor
Cheers @Paul C.
If a Floor Sensor fails unfortunately you have to replace it or use a specialist thermostat. The floor temperature has to be registered, if not you run the risk of over heating the floor and burning out the cable as there is nothing to monitor the cable. The air sensor isn't usable on its own due to the temperature difference between the floor and thermostats mounted point.
We do however have a product we sell made by Elektra which was made for this purpose. It's called a Elektra IR, the IR Stands for Infra Red. This thermostat has a infra red beam which hits the floor and beams back the temperature of the floor. This thermostat is only programmable but is worth every penny.
Digital Programmable Thermostat c/w Infra-Red Floor Sensor - https://www.uheat.co.uk/digital-programmable-thermostat-c-w-infra-red-floor-sensor/
Tile Shop
Only really of use in a kitchen or living area sadly but a great idea
Why not bathroom? Is it because of the air temperature and humidity between the sensor and the floor giving an inaccurate reading? From the way I have read it, the sensor is separate from the thermostat which can still be mounted outside the room so that part of it shouldn't be an issue, unless the sensor isn't waterproof?
Q
Qwerty
Because most bathrooms do not have the thermostat mounted inside the room.
Even if the thermostat was in the room, most bathrooms are not big enough to facilitate it being safely mounted in the correct zone to comply with regs
Uheat - Jake
TF Official Sponsor
The thermostat has the sensor built in the bottom of the thermostat so therefore a bathroom is a no go as it's also only rated IP31 which isn't suitable for moisture.
Tile Shop
Ok. Thanks for clarifying. I looked at the picture of it and you can't see the sensor so I thought it may be some sort of additional attachment that plugged in to the stat.
Reply to Underfloor heating probe in the Tiling on Underfloor Heating area at TilersForums.com
Midland Commercial
