Mike Chapman
Hi, underfloor heating not working think it's the probe which I can't access, is there an external probe I can use, if so how. Cheers
Discuss Underfloor heating probe in the Tiling on Underfloor Heating area at TilersForums. USA and UK Tiling Forum
Only really of use in a kitchen or living area sadly but a great idea
Why not bathroom? Is it because of the air temperature and humidity between the sensor and the floor giving an inaccurate reading? From the way I have read it, the sensor is separate from the thermostat which can still be mounted outside the room so that part of it shouldn't be an issue, unless the sensor isn't waterproof?
The thermostat has the sensor built in the bottom of the thermostat so therefore a bathroom is a no go as it's also only rated IP31 which isn't suitable for moisture.Why not bathroom? Is it because of the air temperature and humidity between the sensor and the floor giving an inaccurate reading? From the way I have read it, the sensor is separate from the thermostat which can still be mounted outside the room so that part of it shouldn't be an issue, unless the sensor isn't waterproof?
Reply to Underfloor heating probe in the Tiling on Underfloor Heating area at TilersForums.com
