Discuss UFH under limestone tiles advice in the Tiling on Underfloor Heating area at TilersForums. USA and UK Tiling Forum
We are going to lay limestone, 15mm in the kitchen 40m2 on a concrete floor. What is the best way to do UFH?
Initially we looked at using warmup sticky matts with 10mm insulation boards and then flex https://www.tilersforums.com/forums/tile-adhesive/ for the tiles . In reading this forum i understand there is still a risk of cracked tiles. should we use an additional decoupling membrane on top of the electric mat. I want to get it right before the tiles go down.
Bill
Insulation boards, electric cable, SLC to encapsulate the cable then a decoupler then lay limestone with a suitable flexible https://www.tilersforums.com/forums/tile-adhesive/. If you can afford an S2 type then use one of those.
H
hmtiling
Insulation, heat mat, latex, decoupler and tile. Or insulation, ditra heat or vario pro or others, latex or not depending on system and tile.
Id use the first method for two reasons. Firstly, if a tile is ever damaged its easier to remove and not damage cable if latex is used. Secondly, I like to have the stat probe in conduit so if that ever fails can be easily replaced
OP
somerset77
Great thanks.
I recieved a quote from uheat for Electric mats, how do they compare to warmup, prowarm in terms of quality and performance?. The 'noisy flashy' brands are not always the best. Its difficult to work out for a novice. Cheers
macten
Can't fault uheat and their heatbase decoupling mat would be perfect for that job.
OP
somerset77
Thanks, I have had a look at the Vario Pro and then also the DCM pro. Installation of this type of system looks more straight forward than the sticky heat matt method.
From the two it appears the DCM pro would be cheaper to install, with the pro mats having a sticky side which would do away with expensive https://www.tilersforums.com/forums/tile-adhesive/ layer.
Any one got thoughts on the two?
There also seems to be a price range of thermal boards, any recommendations?
Reply to UFH under limestone tiles advice in the Tiling on Underfloor Heating area at TilersForums.com
05jtaylor
I've Disabled AdBlock
