Discuss Trim / Grout Problem in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
White tiles, metro pattern. The tiles have bevelled edges, that is, there is a 1 mm difference in thickness between a whole and cut tiles (edges). Trims are white too, very thin, straight edge. Grout is dark.
Problem: if you grout as normal, there will be an ugly uneven dark line alongside the trim.
Solution 1: make an even space between a trim and an edge, same size as spaces between tiles.
Solution 2: cover edges with a masking tape, then grout edges separately with white grout.
What would you recommend?
I did as normal, when grout began to set I removed excess around the trim with a spatula.
Reply to Trim / Grout Problem in the America area at TilersForums.com
Midland Commercial
