Discuss tiling over paint (yet again) in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
White Room
better so plaster would be the best option then... but would it take more than one day for the browning coat to dry and then the finishing coat put over it?
The finsh should be put on the same day the undercoat is applied
what adhesive should i use on a cement render?
Render is a different material to plaster (gypsum)
I would use a powdered adhesive but prime the gypsum plaster first with mapei g or bal apd acrylic primer
G
goatboy
and why is PVA bad when acrylic primer is ok? that bit confuses me because acrylic primer has the same effect when it is dampened to PVA
G
goatboy
p.s. sorry for all the dumb *** questions but i want to get this right in my head before i talk to the guy doing the 'plastering' for want of a better word
G
goatboy
fair doos so reading that if it was a cement render on the wall then i could tile directly without priming it because there wouldnt be a problem with the gypsom/ tile adhesive reaction??
G
goatboy
cool just hope this dude can render the walls in cement and get it flat enough for me to tile onto... does that PVA advice apply when rendering the wall in the first place I wonder??
White Room
If the walls are cleaned of well when the existing finish is taken off, it should need to be dampened with water for the new render
G
goatboy
so all the original paint on the bricks needs to be gotten rid of before it can be rendered then (sorry to go off the tiling topic a little)
Reply to tiling over paint (yet again) in the UK Tiling Forum area at TilersForums.com
Matthew77
