Discuss Tiling dispute in the Tiling Forum area at TilersForums.com
jcrtiling
Getting away with it
Trusted Advisor
TTA Member
Tilers' Arms Member
Who are you feeling with is it the fitter or the contracts manager . Are you speaking to him or communicating by email, are you copying in the branch manager ,
OP
Chelly
New to TilersForums.com
Unfortunately the fitter has washed his hands of it. What happens next is remedial fitters come to complete snags, arranged by Wickes customer services. As I listed a number of issues including tiles and items that have not yet been completed then it gets escalated to customer relations who is the go between. They are liaising with the installation manager who is the one who said when he came to inspect that it is British Standard to start with full tile at bath and that he believes that this is acceptable work. He doesn’t respond to their emails and just doesn’t seem to care. If they phone me I follow up with an email. Wickes guarantee all of the work so my beef is with them.
Boggs
Esteemed Member
Tilers' Arms Member
“Fitter’s washes his hands of it”
How can he, surely he is the one responsible as he was the one who fitted it.
OP
Chelly
Sorry, bit late to the party on this one, but here goes:
BS5385 part 1-2018 - 7.1.5 Setting out
Unsightly cut tiles should be avoided
and joints should be of a uniform width, true to a line, continuous without steps: allowance should be made for an adequate width of joint. Cut course, both vertical and horizontal, should be:
a) kept to a minimum
b) determined in advance
c) as large as possible
d) arranged in the least prominent locations
Where wall surfaces are interrupted by features, e.g. windows, access panels or sanitary fittings, the tile fixer should seek guidance from the designer as to the setting out to be adopted; similar guidance might be required in the positioning of movement joints, since they are predominant and could determine the setting out pattern.
Horizontal joints and cut courses should be positioned depending on several factors, of which the following are examples.
1) Tiled areas that adjoin or are adjacent should be set out so that horizontal joints are aligned
2) The upper and/or lower extremities of the wall might not be level, requiring a course or courses to be cut with a raking edge. Wherever possible, the horizontal joints should be positioned so that the whole of the rake can be taken up within the height of the tile in the cut course.
3) If it is thought desirable to align a joint with a feature, this becomes the setting out point and might initiate the need for, and frequently dictate the location of, cut courses elsewhere.
4) To ensure the rows are truly horizontal, a level line should be established to position the starting course. This line should be continuous across all tile surfaces.
Thank you so much Paul, and the party is still going strong :p , will definitely be sending this information to them. You have all be such a great help thank you!
antonio
JOTM Winner
Trusted Advisor
Tilers' Arms Member
sorry, i was wrong
antonio
JOTM Winner
Trusted Advisor
Tilers' Arms Member
should, could, where possible.......
seems very vague
very different from uni standards.
they must be is better than they should.
or is the translator wrong?
Balloo
Tilers' Arms Member
I'm pretty sure that it's not in British standards to start a full tile from the bath. @Paul C. Could confirm this.
The transitions should be a silicone joint which should be in British standards. It's a bad job and I think they're lying about the B. S.
Absolutely nonsense and misinformation BS is not a about that , its only a guideline for standard practice .
Balloo
Tilers' Arms Member
I look at all trades and the crap they dish out , and a tiler is caught out by a crap ceiling not level nor probably walls plumb , and the whole world condemns the job .
take a look at yourselves is this really worth a dispute .
ok he should have checked the cuts to ceiling but seriously some of the dib and dab jobs on floors is more significant obviously because of the cost of fixing broken tiles.
hmtiling
JOTM Winner
Trusted Advisor
Tilers' Arms Member
I certainly wouldn't let it slide if it was my house. Are you saying you would?
Paul C.
Trusted Advisor
Tilers' Arms Member
"Caught out".... He wouldn't have been if he'd planned it correctly instead of being lazy and assuming a full tile from a convenient point would be ok. Setting out and good preparation is a tilers job, part of the service. Either the ceiling could have been sorted, tiles laid out to suit a bigger cut and less of an eye-sore, or have a discussion with the customer how to proceed, stick it in their court... Not wing it and say "sorry, best I could do".
So taking a look at myself as you asked and yes, I would still dispute. It looks arse. Aside from practicality, aesthetics is a huge part of why tiles are used. And that is certainly not aesthetically pleasing to me.
pjc
Trusted Advisor
Tilers' Arms Member
Have made the mistake when I first started but removed them and redone it.
Tim Saunders
I'm guessing the installer was on a price or on a time...I've always taken my time setting out purposely to avoid problems like this..if you've got a room with a bath, couple of windows and maybe a shower tray then it can take a while to get your head round how it's going to work out and I always discuss the layout with the client beforehand to make sure they're happy before I start fixing
  • :athleticshoe:
  • :bikini:
  • :briefcase:
  • :closedumbrella:
  • :dress:
  • :eyeglasses:
  • :gradcap:
  • :handbag:
  • :headphones:
  • :highheel:
  • :jeans:
  • :kimono:
  • :lipstick:
  • :mansshoe:
  • :namebadge:
  • :necktie:
  • :pouch:
  • :purse:
  • :ribbon:
  • :ring:
  • :runshirtsash:
  • :schoolsatchel:
  • :tophat:
  • :tshirt:
  • :umbrellarain:
  • :watch:
  • :womansboots:
  • :womansclothes:
  • :womanshat:
  • :womanssandal:
  • :mad:
  • :confused:
  • :cool:
  • :p
  • :D
  • :eek:
  • :oops:
  • :rolleyes:
  • o_O
  • :angry:
  • :anguished:
  • :astonished:
  • :blush:
  • :coldsweat:
  • :confounded:
  • :confused2:
  • :cry:
  • :cryingcat:
  • :disappointed:
  • :disrelieved:
  • :dizzy:
  • :expressionless:
  • :fearscream:
  • :fearful:
  • :flushed:
  • :frowning:
  • :grimacing:
  • :grin:
  • :grinning:
  • :hearteyes:
  • :hearteyecat:
  • :hushed:
  • :imp:
  • :innocent:
  • :joycat:
  • :kissing:
  • :kissingcat:
  • :kissingclosed:
  • :kissingheart:
  • :kissingsmiling:
  • :laughing:
  • :mask:
  • :neutral:
  • :nomouth:
  • :openmouth:
  • :pensive:
  • :persevere:
  • :poutingcat:
  • :rage:
  • :relaxed:
  • :relieved:
  • :screamcat:
  • :sleeping:
  • :sleepy:
  • :smile:
  • :smilecat:
  • :smiley:
  • :smileycat:
  • :smilingimp:
  • :smirk:
  • :smirkcat:
  • :sob:
  • :sunglasses:
  • :sweat:
  • :sweatsmile:
  • :tearsofjoy:
  • :tired:
  • :tongueclosed:
  • :tongueout:
  • :tonguewink:
  • :triumph:
  • :unamused:
  • :weary:
  • :wink:
  • :worried:
  • :yum:
  • :arrowback:
  • :arrowdown:
  • :arrowheaddown:
  • :arrowheadup:
  • :arrowright:
  • :arrowsmalldown:
  • :arrowsmallup:
  • :arrowup:
  • :abcd:
  • :cinema:
  • :clockwiserightleftarrow:
  • :clockrlopen:
  • :counterclockupdown:
  • :doubledown:
  • :doubleup:
  • :eight:
  • :fastforward:
  • :five:
  • :four:
  • :hashtag:
  • :infosource:
  • :larrowhook:
  • :lrarrow:
  • :letters:
  • :lowerabcd:
  • :nine:
  • :nearrow:
  • :nwarrow:
  • :numbers:
  • :one:
  • :play:
  • :putlitter:
  • :restroom:
  • :rewind:
  • :rarrowhook:
  • :seven:
  • :signalstrength:
  • :six:
  • :skipback:
  • :searrow:
  • :swarrow:
  • :squaredcool:
  • :squaredfree:
  • :katanakoko:
  • :squarednew:
  • :squaredng:
  • :squaredok:
  • :squaredup:
  • :symbols:
  • :ten:
  • :three:
  • :topwarrow:
  • :twistedrightarrow:
  • :two:
  • :udarrow:
  • :zero:
  • :swimmer:
  • :taxi:
  • :tractor:
  • :trafficlight:
  • :trafficlight2:
  • :train:
  • :tram:
  • :tramcar:
  • :trolleybus:
  • :truck:
  • :walking:
  • :aerialtramway:
  • :airplane:
  • :ambulance:
  • :bicyclist:
  • :bike:
  • :bluecar:
  • :bullettrain:
  • :bullettrainside:
  • :bus:
  • :car:
  • :fireengine:
  • :helicopter:
  • :lightrail:
  • :locomotive:
  • :lorry:
  • :minibus:
  • :monorail:
  • :mountaincableway:
  • :mountainrailway:
  • :mountainbiker:
  • :oncomingbus:
  • :oncomingcar:
  • :oncomingpolice:
  • :oncomingtaxi:
  • :policecar:
  • :railwaycar:
  • :rocket:
  • :rowboat:
  • :runner:
  • :sailboat:
  • :snowboarder:
  • :speedboat:
  • :station:
  • :surfer:
  • :suspensionrailway:
  • :ant:
  • :babychick:
  • :bactriancamel:
  • :bearface:
  • :bee:
  • :beetle:
  • :bird:
  • :blossom:
  • :blowfish:
  • :boar:
  • :bug:
  • :cactus:
  • :cat:
  • :catface:
  • :cherryblossom:
  • :chicken:
  • :cow:
  • :cowface:
  • :crocodile:
  • :deciduous:
  • :dog:
  • :dogface:
  • :dolphin:
  • :dragon:
  • :dragonface:
  • :dromedarycamel:
  • :elephant:
  • :evergreen:
  • :fallenleaf:
  • :fish:
  • :fourleaf:
  • :frogface:
  • :goat:
  • :hamsterface:
  • :hatchedchick:
  • :hatchingchick:
  • :herb:
  • :hibiscus:
  • :horseface:
  • :horseracing:
  • :koala:
  • :leafwind:
  • :leopard:
  • :mapleleaf:
  • :monkey:
  • :monkeyface:
  • :mouse:
  • :mouseface:
  • :ocean:
  • :octopus:
  • :ox:
  • :palmtree:
  • :pandaface:
  • :penguin:
  • :pig:
  • :pigface:
  • :pignose:
  • :poodle:
  • :rabbit:
  • :rabbitface:
  • :racehorse:
  • :ram:
  • :rat:
  • :rooster:
  • :rose:
  • :seedling:
  • :sheep:
  • :snail:
  • :snake:
  • :snowflake:
  • :snowman:
  • :spiralshell:
  • :spoutingwhale:
  • :sunflower:
  • :tanabata:
  • :tiger:
  • :tigerface:
  • :tropicalfish:
  • :tulip:
  • :turtle:
  • :waterbuffalo:
  • :whale:
  • :wolfface:
  • :banana:
  • :beercheers:
  • :beermug:
  • :bread:
  • :candy:
  • :candybar:
  • :cherries:
  • :chestnut:
  • :chickenleg:
  • :cocktail:
  • :coffee:
  • :cookie:
  • :cookingegg:
  • :curryrice:
  • :custard:
  • :dango:
  • :doughnut:
  • :maize:
  • :rice:
  • :eggplant:
  • :fishcake:
  • :frenchfries:
  • :friedshrimp:
  • :grapes:
  • :greenapple:
  • :hamburger:
  • :honeypot:
  • :icecream:
  • :icecreamcone:
  • :lemon:
  • :lollipop:
  • :meatbone:
  • :melon:
  • :mushroom:
  • :oden:
  • :peach:
  • :pear:
  • :pineapple:
  • :pizza:
  • :ramen:
  • :redapple:
  • :riceball:
  • :ricecooked:
  • :ricecracker:
  • :sake:
  • :shavedice:
  • :shortcake:
  • :spaghetti:
  • :stew:
  • :strawberry:
  • :sushi:
  • :sweetpotato:
  • :tangerine:
  • :teacup:
  • :tomato:
  • :tropicaldrink:
  • :watermelon:
  • :wineglass:
  • :bank:
  • :bridgenight:
  • :busstop:
  • :carouselhorse:
  • :china:
  • :church:
  • :circustent:
  • :citysunrise:
  • :cityscapedusk:
  • :conveniencestore:
  • :departmentstore:
  • :eurocastle:
  • :europo:
  • :factory:
  • :ferriswheel:
  • :fsparkler:
  • :fireworks:
  • :foggy:
  • :fountain:
  • :france:
  • :germany:
  • :greatbritain:
  • :hospital:
  • :hotel:
  • :house:
  • :housegarden:
  • :italy:
  • :japan:
  • :japanesecastle:
  • :japanesepo:
  • :korea:
  • :lovehotel:
  • :milkyway:
  • :moonceremony:
  • :mtfuji:
  • :nightstars:
  • :officebuilding:
  • :rainbow:
  • :rollercoaster:
  • :russia:
  • :school:
  • :ship:
  • :shootingstar:
  • :silhouettejapan:
  • :spain:
  • :statueofliberty:
  • :sunrise:
  • :sunrisemountains:
  • :tent:
  • :tokyotower:
  • :unitedstates:
  • :volcano:
  • :wedding:
  • :wmssquare:
  • :wmsquare:
  • :wssquare:
  • :wsbutton:
  • :womens:
  • :yellowheart:
  • :100:
  • :angersymbol:
  • :aquarius:
  • :aries:
  • :asterisk:
  • :atm:
  • :babysymbol:
  • :backwarrow:
  • :baggageclaim:
  • :ballotcheck:
  • :barchart:
  • :blsquare:
  • :bmssquare:
  • :bmsquare:
  • :bssquare:
  • :bsbutton:
  • :blueheart:
  • :boom:
  • :brokenheart:
  • :bustsilhouette:
  • :bustsinsilhouette:
  • :cancer:
  • :capitala:
  • :capitalb:
  • :capitalo:
  • :capitalp:
  • :capricorn:
  • :chartdown:
  • :chartupyen:
  • :chartingup:
  • :childrencrossing:
  • :circle:
  • :circlem:
  • :u5272:
  • :u5408:
  • :u55b6:
  • :u6307:
  • :u6708:
  • :u6709:
  • :u6e80:
  • :u7121:
  • :u7533:
  • :u7981:
  • :u7a7a:
  • :clockdownupopen:
  • :congrats:
  • :copyright:
  • :crossmark:
  • :curlyloop:
  • :currencyexchange:
  • :customs:
  • :cyclone:
  • :diamonddot:
  • :dashsymbol:
  • :division:
  • :dizzysymbol:
  • :donotlitter:
  • :dollarsign:
  • :doublecurlyloop:
  • :email:
  • :emailsymbol:
  • :endwarrow:
  • :envelopearrow:
  • :exclamation:
  • :exclamationarrow:
  • :footprints:
  • :gemini:
  • :glowingstar:
  • :greencross:
  • :greenheart:
  • :heart:
  • :heartdecoration:
  • :heartpulse:
  • :heartarrow:
  • :heartribbon:
  • :heartbeat:
  • :heavycheck:
  • :heavymultiply:
  • :highbrightness:
  • :zap:
  • :hotsprings:
  • :accept:
  • :advantage:
  • :japanesebeginner:
  • :largebluecircle:
  • :largebluediamond:
  • :largeorangediamond:
  • :largeredcircle:
  • :leftluggage:
  • :leo:
  • :libra:
  • :lowbrightness:
  • :reddragon:
  • :mbcircle:
  • :mwcirlce:
  • :mens:
  • :metro:
  • :minus:
  • :mobileoff:
  • :mobilevibration:
  • :musicnotes:
  • :musicalnote:
  • :musicalscore:
  • :nobikes:
  • :noentry:
  • :noentrysign:
  • :nomobile:
  • :no18:
  • :nopedestrians:
  • :nosmoking:
  • :nonpotablewater:
  • :ophiuchus:
  • :4star:
  • :pamark:
  • :partlysunny:
  • :passportcontrol:
  • :pawprints:
  • :peace:
  • :picses:
  • :plus:
  • :pointup:
  • :potablewater:
  • :purpleheart:
  • :question:
  • :questionwhite:
  • :radiobutton:
  • :recycle:
  • :registered:
  • :sagittarius:
  • :scorpius:
  • :secret:
  • :sixpointedstar:
  • :sleepsymbol:
  • :smallbluediamond:
  • :smallorangediamond:
  • :smallredtriangle:
  • :smallredtriangledown:
  • :soonarrow:
  • :sparkle:
  • :sparkles:
  • :sparklingheart:
  • :squaredab:
  • :squaredcl:
  • :squaredid:
  • :katanasa:
  • :squaredsos:
  • :squaredvs:
  • :star:
  • :taurus:
  • :tm:
  • :tridentemblem:
  • :twohearts:
  • :virgo:
  • :warning:
  • :watercloset:
  • :wavydash:
  • :wheelchair:
  • :whitecheck:
  • :whiteexclamation:
  • :whiteflower:
  • :wlsquare:
  • :blacksunrays:
  • :cloud:
  • :crescentmoon:
  • :earthamericas:
  • :earthasiaaus:
  • :eartheurafr:
  • :firstqmoon:
  • :firstqmoonface:
  • :fullmoon:
  • :fullmoonface:
  • :globemeridians:
  • :lastqmoon:
  • :lastqmoonface:
  • :newmoon:
  • :newmoonface:
  • :sunface:
  • :wancrescent:
  • :wangibbous:
  • :waxcrescent:
  • :waxgibbous:
  • :time10:
  • :time1030:
  • :time11:
  • :time1130:
  • :time12:
  • :time1230:
  • :time1:
  • :time130:
  • :time2:
  • :time230:
  • :time3:
  • :time330:
  • :time4:
  • :time430:
  • :time5:
  • :time530:
  • :time6:
  • :time630:
  • :time7:
  • :time730:
  • :time8:
  • :time830:
  • :time9:
  • :time930:
  • :coupleheart:
  • :dancer:
  • :dancers:
  • :ear:
  • :family:
  • :fist:
  • :girl:
  • :guapimo:
  • :guardsman:
  • :haircut:
  • :hand:
  • :handfist:
  • :handok:
  • :handpointdown:
  • :handpointleft:
  • :handpointright:
  • :handpointup:
  • :handwaving:
  • :clapping:
  • :handsopen:
  • :praying:
  • :headmassage:
  • :infodeskperson:
  • :man:
  • :holdinghands:
  • :menholdinghands:
  • :mouth:
  • :nailpolish:
  • :nogood:
  • :nose:
  • :okay:
  • :oldman:
  • :oldwoman:
  • :personblonde:
  • :personfrowning:
  • :personpouting:
  • :policeofficer:
  • :princess:
  • :raisedhands:
  • :raisinghand:
  • :santa:
  • :thumbsdown:
  • :thumbsup:
  • :tongue:
  • :turban:
  • :woman:
  • :womenholdinghands:
  • :baby:
  • :babyangel:
  • :bowing:
  • :boy:
  • :bride:
  • :constructionworker:
  • :couplekiss:
  • :8ball:
  • :alarmclock:
  • :alien:
  • :anchor:
  • :artpalette:
  • :babybottle:
  • :balloon:
  • :dollar:
  • :euro:
  • :gbp:
  • :yen:
  • :barberpole:
  • :baseball:
  • :basketball:
  • :bath:
  • :bathtub:
  • :battery:
  • :bell:
  • :bellcancel:
  • :bento:
  • :birthdaycake:
  • :blacknib:
  • :blacktelephone:
  • :bluebook:
  • :bomb:
  • :bookmark:
  • :bookmarktab:
  • :books:
  • :bouquet:
  • :bowling:
  • :calendar:
  • :camera:
  • :carpstreamer:
  • :cd:
  • :checkeredflag:
  • :christmastree:
  • :clapperboard:
  • :clipboard:
  • :closedbook:
  • :closedlockkey:
  • :clubs:
  • :confettiball:
  • :construction:
  • :creditcard:
  • :crossedflags:
  • :crown:
  • :crystalball:
  • :darts:
  • :date:
  • :diamondsuit:
  • :door:
  • :droplet:
  • :dvd:
  • :electricplug:
  • :eyes:
  • :fax:
  • :filefolder:
  • :fire:
  • :flagstick:
  • :flashlight:
  • :floppy:
  • :flowercards:
  • :football:
  • :forkknife:
  • :fuelpump:
  • :gamedie:
  • :gemstone:
  • :ghost:
  • :gift:
  • :greenbook:
  • :guitar:
  • :gun:
  • :hammer:
  • :hearnoevil:
  • :heartssuit:
  • :hourglass:
  • :hourglasssand:
  • :inbox:
  • :incomingenvelope:
  • :iphone:
  • :isakayalantern:
  • :jackolantern:
  • :japanesedolls:
  • :japanesegoblin:
  • :japaneseogre:
  • :jokercard:
  • :key:
  • :kiss:
  • :knife:
  • :ledger:
  • :leftmagnify:
  • :lightbulb:
  • :link:
  • :lock:
  • :lockink:
  • :loudspeaker:
  • :loveletter:
  • :mailclosedflaglower:
  • :mailclosedflagup
  • :mailopenflaglower:
  • :mailopenflagup:
  • :megaphone:
  • :memo:
  • :microphone:
  • :microscope:
  • :minidisc:
  • :mobilecalling:
  • :moneybag:
  • :moneywings:
  • :moviecamera:
  • :moyai:
  • :musickeyboard:
  • :mute:
  • :newspaper:
  • :notebook:
  • :notebookdecorative:
  • :nutbolt:
  • :openbook:
  • :openfile:
  • :openlock:
  • :orangebook:
  • :outbox:
  • :package:
  • :pagefaceup:
  • :pagecurl:
  • :pager:
  • :paperclip:
  • :partypooper:
  • :pencil:
  • :performingarts:
  • :personalcomputer:
  • :pill:
  • :pinedecoration:
  • :pileofpoop:
  • :postalhorn:
  • :postbox:
  • :pushpin:
  • :radio:
  • :rightmagnify:
  • :roladex:
  • :rotatinglight:
  • :roundpushpin:
  • :rugby:
  • :satellite:
  • :sax:
  • :scissors:
  • :scroll:
  • :seat:
  • :seenoevil:
  • :shower:
  • :skis:
  • :skull:
  • :slotmachine:
  • :smoking:
  • :soccerball:
  • :spaceinvader:
  • :spades:
  • :speaknoevil:
  • :speaker:
  • :speakerone:
  • :speakerthree:
  • :speechballoon:
  • :straightruler:
  • :sweatdrops:
  • :syringe:
  • :telephonereceiver:
  • :telescope:
  • :television:
  • :tennisball:
  • :thoughtballoon:
  • :ticket:
  • :toilet:
  • :triangularruler:
  • :triangularflag:
  • :trophy:
  • :trumpet:
  • :vhs:
  • :videocamera:
  • :videogame:
  • :violin:
  • :windchime:
  • :wrench:
Top Bottom
