Discuss Tiling dispute in the Tiling Forum area at TilersForums.com
OP
Chelly
New to TilersForums.com
Depending on how the room sets out determins whether you have full tiles on the bath or not. You usually dont because baths are rarely set level lol. Nobody bothered setting out that room and theyve been found out. Theyre talking bollards
Yes they have! Just need to get them (wickes) to listen now :)
Tom Astley
Tilers' Arms Member
Am I the only one who thinks the ceiling should be level? Why spend all that money and have a poor finish?
OP
Chelly
I did have the ceiling walls skimmed and wasn’t aware that it wasn’t level until that was another excuse given by the installer. I did ask why he didn’t tell me at time of skimming he said he didn’t know. If I had known I would have rectified that. Ignorance on my part.
OP
Chelly
It will show but won't poke you in the eyes as it does now
What I mean is, still using the same size tile as I have, I understand that I would have had a 20mm graduation but if he had set out probably the final tile would have been a larger cut so not do noticeable?
Tony_C
Admired Member
Esteemed Member
Tilers' Arms Member
There is possibly a chance they measured up on the shower wall only and deemed the 20mm or so cut acceptable but had no idea the ceiling was so out until it was too late when it got to another wall. not saying it's acceptable just an idea as to how it happened to them
As suggested you could get a coving up or possibly a big white silicone line to at least cover that cut that is purely grout as it could take your eye away from that and make it look more like just a grout line
3_fall
Administrator.
Staff member
JOTM Winner
Trusted Advisor
Tilers' Arms Member
Regardless of the fact that the ceiling may be out of level, if you tried that set out on site, you’d be lucky not to be swinging from the scaffold, but I suppose more likely sent off site never to return or be paid.
Good practice is to have at least one third of a tile as a cut, some QS want larger, but a third is generally acceptable.
Last time I was on site anyway. :)
And as far as a full tile off the bath goes, if we did that, 90% of our work would be out of level.
3_fall
Administrator.
Staff member
JOTM Winner
Trusted Advisor
Tilers' Arms Member
No you’re not Tom, do you refuse to tile a room then if the ceiling isn’t level? :p Haha
OP
Chelly
Haha Thanks @3_fall
Tom Astley
Tilers' Arms Member
No but 99% of the tilers on here keep banging on about how things are done .... blah blah blah .....so why not go ape about the ceiling like you would do if the walls were not plumb and flat.
A little bit hypocritical methinks, sometimes.
Andystiletiling
JOTM Winner
Trusted Advisor
Tilers' Arms Member
At what point does the customer inform the plasterer it must be level not 20mm out over 3 metres oh and they've picked metros...
Plasterer turns up JUST to skim ceiling as booked, just as he's mixed a bucket of skim customer informs him it must be level, plasterer then rings tiler to drop everything and immediatley rush over to site FOC, pings a datum round the room and set ceiling up, by this time plasterers skims gone off and ruined his gorilla tub... Plasterer shouts and screams and walks off job..
Next available plasterer that can get there throws all the schedules out and tilers and plumbers are not now available, so plasterer says "I've done a bit of tiling and plumbing" he ends up tiling it and making a right mess of fixing and the set out, connects shower up and floods the house, and customer then ends back up on here complaining about the job..full circle..
You know the script in the real world Tom, it won't happen..
Ps. No offense @widler
impish
Trusted Advisor
Tilers' Arms Member
I think it's a shame that someone uses a nationwide firm to do some work which wouldn't be cheap and ends up with a below par job.
We know better and have hindsight but I think as a customer you kind of expect wickes to be offering more than Joe blogs tiling services from the yellow pages.
Absolute rubbish from wickes and their excuses are as ill-thought out as the set out.
I'd love to have a chat with whoever is in charge...
OP
Chelly
You would think so wouldn’t you! Unfortunately they don’t seem to be very chatty:p
MissTiler
TTA Tile Fixer of the year winner 2017
JOTM Winner
Trusted Advisor
TTA Member
Tilers' Arms Member
Have you thought about getting a report from The Tile Association done? Not sure of the cost off hand.
Paul C.
Trusted Advisor
Tilers' Arms Member
Sorry, bit late to the party on this one, but here goes:
BS5385 part 1-2018 - 7.1.5 Setting out
Unsightly cut tiles should be avoided
and joints should be of a uniform width, true to a line, continuous without steps: allowance should be made for an adequate width of joint. Cut course, both vertical and horizontal, should be:
a) kept to a minimum
b) determined in advance
c) as large as possible
d) arranged in the least prominent locations
Where wall surfaces are interrupted by features, e.g. windows, access panels or sanitary fittings, the tile fixer should seek guidance from the designer as to the setting out to be adopted; similar guidance might be required in the positioning of movement joints, since they are predominant and could determine the setting out pattern.
Horizontal joints and cut courses should be positioned depending on several factors, of which the following are examples.
1) Tiled areas that adjoin or are adjacent should be set out so that horizontal joints are aligned
2) The upper and/or lower extremities of the wall might not be level, requiring a course or courses to be cut with a raking edge. Wherever possible, the horizontal joints should be positioned so that the whole of the rake can be taken up within the height of the tile in the cut course.
3) If it is thought desirable to align a joint with a feature, this becomes the setting out point and might initiate the need for, and frequently dictate the location of, cut courses elsewhere.
4) To ensure the rows are truly horizontal, a level line should be established to position the starting course. This line should be continuous across all tile surfaces.
OP
Chelly
I looked at this last night, think it is about £800 for a report but I will give them a ring, seems pricey but maybe a last resort
  • :athleticshoe:
  • :bikini:
  • :briefcase:
  • :closedumbrella:
  • :dress:
  • :eyeglasses:
  • :gradcap:
  • :handbag:
  • :headphones:
  • :highheel:
  • :jeans:
  • :kimono:
  • :lipstick:
  • :mansshoe:
  • :namebadge:
  • :necktie:
  • :pouch:
  • :purse:
  • :ribbon:
  • :ring:
  • :runshirtsash:
  • :schoolsatchel:
  • :tophat:
  • :tshirt:
  • :umbrellarain:
  • :watch:
  • :womansboots:
  • :womansclothes:
  • :womanshat:
  • :womanssandal:
  • :mad:
  • :confused:
  • :cool:
  • :p
  • :D
  • :eek:
  • :oops:
  • :rolleyes:
  • o_O
  • :angry:
  • :anguished:
  • :astonished:
  • :blush:
  • :coldsweat:
  • :confounded:
  • :confused2:
  • :cry:
  • :cryingcat:
  • :disappointed:
  • :disrelieved:
  • :dizzy:
  • :expressionless:
  • :fearscream:
  • :fearful:
  • :flushed:
  • :frowning:
  • :grimacing:
  • :grin:
  • :grinning:
  • :hearteyes:
  • :hearteyecat:
  • :hushed:
  • :imp:
  • :innocent:
  • :joycat:
  • :kissing:
  • :kissingcat:
  • :kissingclosed:
  • :kissingheart:
  • :kissingsmiling:
  • :laughing:
  • :mask:
  • :neutral:
  • :nomouth:
  • :openmouth:
  • :pensive:
  • :persevere:
  • :poutingcat:
  • :rage:
  • :relaxed:
  • :relieved:
  • :screamcat:
  • :sleeping:
  • :sleepy:
  • :smile:
  • :smilecat:
  • :smiley:
  • :smileycat:
  • :smilingimp:
  • :smirk:
  • :smirkcat:
  • :sob:
  • :sunglasses:
  • :sweat:
  • :sweatsmile:
  • :tearsofjoy:
  • :tired:
  • :tongueclosed:
  • :tongueout:
  • :tonguewink:
  • :triumph:
  • :unamused:
  • :weary:
  • :wink:
  • :worried:
  • :yum:
  • :arrowback:
  • :arrowdown:
  • :arrowheaddown:
  • :arrowheadup:
  • :arrowright:
  • :arrowsmalldown:
  • :arrowsmallup:
  • :arrowup:
  • :abcd:
  • :cinema:
  • :clockwiserightleftarrow:
  • :clockrlopen:
  • :counterclockupdown:
  • :doubledown:
  • :doubleup:
  • :eight:
  • :fastforward:
  • :five:
  • :four:
  • :hashtag:
  • :infosource:
  • :larrowhook:
  • :lrarrow:
  • :letters:
  • :lowerabcd:
  • :nine:
  • :nearrow:
  • :nwarrow:
  • :numbers:
  • :one:
  • :play:
  • :putlitter:
  • :restroom:
  • :rewind:
  • :rarrowhook:
  • :seven:
  • :signalstrength:
  • :six:
  • :skipback:
  • :searrow:
  • :swarrow:
  • :squaredcool:
  • :squaredfree:
  • :katanakoko:
  • :squarednew:
  • :squaredng:
  • :squaredok:
  • :squaredup:
  • :symbols:
  • :ten:
  • :three:
  • :topwarrow:
  • :twistedrightarrow:
  • :two:
  • :udarrow:
  • :zero:
  • :swimmer:
  • :taxi:
  • :tractor:
  • :trafficlight:
  • :trafficlight2:
  • :train:
  • :tram:
  • :tramcar:
  • :trolleybus:
  • :truck:
  • :walking:
  • :aerialtramway:
  • :airplane:
  • :ambulance:
  • :bicyclist:
  • :bike:
  • :bluecar:
  • :bullettrain:
  • :bullettrainside:
  • :bus:
  • :car:
  • :fireengine:
  • :helicopter:
  • :lightrail:
  • :locomotive:
  • :lorry:
  • :minibus:
  • :monorail:
  • :mountaincableway:
  • :mountainrailway:
  • :mountainbiker:
  • :oncomingbus:
  • :oncomingcar:
  • :oncomingpolice:
  • :oncomingtaxi:
  • :policecar:
  • :railwaycar:
  • :rocket:
  • :rowboat:
  • :runner:
  • :sailboat:
  • :snowboarder:
  • :speedboat:
  • :station:
  • :surfer:
  • :suspensionrailway:
  • :ant:
  • :babychick:
  • :bactriancamel:
  • :bearface:
  • :bee:
  • :beetle:
  • :bird:
  • :blossom:
  • :blowfish:
  • :boar:
  • :bug:
  • :cactus:
  • :cat:
  • :catface:
  • :cherryblossom:
  • :chicken:
  • :cow:
  • :cowface:
  • :crocodile:
  • :deciduous:
  • :dog:
  • :dogface:
  • :dolphin:
  • :dragon:
  • :dragonface:
  • :dromedarycamel:
  • :elephant:
  • :evergreen:
  • :fallenleaf:
  • :fish:
  • :fourleaf:
  • :frogface:
  • :goat:
  • :hamsterface:
  • :hatchedchick:
  • :hatchingchick:
  • :herb:
  • :hibiscus:
  • :horseface:
  • :horseracing:
  • :koala:
  • :leafwind:
  • :leopard:
  • :mapleleaf:
  • :monkey:
  • :monkeyface:
  • :mouse:
  • :mouseface:
  • :ocean:
  • :octopus:
  • :ox:
  • :palmtree:
  • :pandaface:
  • :penguin:
  • :pig:
  • :pigface:
  • :pignose:
  • :poodle:
  • :rabbit:
  • :rabbitface:
  • :racehorse:
  • :ram:
  • :rat:
  • :rooster:
  • :rose:
  • :seedling:
  • :sheep:
  • :snail:
  • :snake:
  • :snowflake:
  • :snowman:
  • :spiralshell:
  • :spoutingwhale:
  • :sunflower:
  • :tanabata:
  • :tiger:
  • :tigerface:
  • :tropicalfish:
  • :tulip:
  • :turtle:
  • :waterbuffalo:
  • :whale:
  • :wolfface:
  • :banana:
  • :beercheers:
  • :beermug:
  • :bread:
  • :candy:
  • :candybar:
  • :cherries:
  • :chestnut:
  • :chickenleg:
  • :cocktail:
  • :coffee:
  • :cookie:
  • :cookingegg:
  • :curryrice:
  • :custard:
  • :dango:
  • :doughnut:
  • :maize:
  • :rice:
  • :eggplant:
  • :fishcake:
  • :frenchfries:
  • :friedshrimp:
  • :grapes:
  • :greenapple:
  • :hamburger:
  • :honeypot:
  • :icecream:
  • :icecreamcone:
  • :lemon:
  • :lollipop:
  • :meatbone:
  • :melon:
  • :mushroom:
  • :oden:
  • :peach:
  • :pear:
  • :pineapple:
  • :pizza:
  • :ramen:
  • :redapple:
  • :riceball:
  • :ricecooked:
  • :ricecracker:
  • :sake:
  • :shavedice:
  • :shortcake:
  • :spaghetti:
  • :stew:
  • :strawberry:
  • :sushi:
  • :sweetpotato:
  • :tangerine:
  • :teacup:
  • :tomato:
  • :tropicaldrink:
  • :watermelon:
  • :wineglass:
  • :bank:
  • :bridgenight:
  • :busstop:
  • :carouselhorse:
  • :china:
  • :church:
  • :circustent:
  • :citysunrise:
  • :cityscapedusk:
  • :conveniencestore:
  • :departmentstore:
  • :eurocastle:
  • :europo:
  • :factory:
  • :ferriswheel:
  • :fsparkler:
  • :fireworks:
  • :foggy:
  • :fountain:
  • :france:
  • :germany:
  • :greatbritain:
  • :hospital:
  • :hotel:
  • :house:
  • :housegarden:
  • :italy:
  • :japan:
  • :japanesecastle:
  • :japanesepo:
  • :korea:
  • :lovehotel:
  • :milkyway:
  • :moonceremony:
  • :mtfuji:
  • :nightstars:
  • :officebuilding:
  • :rainbow:
  • :rollercoaster:
  • :russia:
  • :school:
  • :ship:
  • :shootingstar:
  • :silhouettejapan:
  • :spain:
  • :statueofliberty:
  • :sunrise:
  • :sunrisemountains:
  • :tent:
  • :tokyotower:
  • :unitedstates:
  • :volcano:
  • :wedding:
  • :wmssquare:
  • :wmsquare:
  • :wssquare:
  • :wsbutton:
  • :womens:
  • :yellowheart:
  • :100:
  • :angersymbol:
  • :aquarius:
  • :aries:
  • :asterisk:
  • :atm:
  • :babysymbol:
  • :backwarrow:
  • :baggageclaim:
  • :ballotcheck:
  • :barchart:
  • :blsquare:
  • :bmssquare:
  • :bmsquare:
  • :bssquare:
  • :bsbutton:
  • :blueheart:
  • :boom:
  • :brokenheart:
  • :bustsilhouette:
  • :bustsinsilhouette:
  • :cancer:
  • :capitala:
  • :capitalb:
  • :capitalo:
  • :capitalp:
  • :capricorn:
  • :chartdown:
  • :chartupyen:
  • :chartingup:
  • :childrencrossing:
  • :circle:
  • :circlem:
  • :u5272:
  • :u5408:
  • :u55b6:
  • :u6307:
  • :u6708:
  • :u6709:
  • :u6e80:
  • :u7121:
  • :u7533:
  • :u7981:
  • :u7a7a:
  • :clockdownupopen:
  • :congrats:
  • :copyright:
  • :crossmark:
  • :curlyloop:
  • :currencyexchange:
  • :customs:
  • :cyclone:
  • :diamonddot:
  • :dashsymbol:
  • :division:
  • :dizzysymbol:
  • :donotlitter:
  • :dollarsign:
  • :doublecurlyloop:
  • :email:
  • :emailsymbol:
  • :endwarrow:
  • :envelopearrow:
  • :exclamation:
  • :exclamationarrow:
  • :footprints:
  • :gemini:
  • :glowingstar:
  • :greencross:
  • :greenheart:
  • :heart:
  • :heartdecoration:
  • :heartpulse:
  • :heartarrow:
  • :heartribbon:
  • :heartbeat:
  • :heavycheck:
  • :heavymultiply:
  • :highbrightness:
  • :zap:
  • :hotsprings:
  • :accept:
  • :advantage:
  • :japanesebeginner:
  • :largebluecircle:
  • :largebluediamond:
  • :largeorangediamond:
  • :largeredcircle:
  • :leftluggage:
  • :leo:
  • :libra:
  • :lowbrightness:
  • :reddragon:
  • :mbcircle:
  • :mwcirlce:
  • :mens:
  • :metro:
  • :minus:
  • :mobileoff:
  • :mobilevibration:
  • :musicnotes:
  • :musicalnote:
  • :musicalscore:
  • :nobikes:
  • :noentry:
  • :noentrysign:
  • :nomobile:
  • :no18:
  • :nopedestrians:
  • :nosmoking:
  • :nonpotablewater:
  • :ophiuchus:
  • :4star:
  • :pamark:
  • :partlysunny:
  • :passportcontrol:
  • :pawprints:
  • :peace:
  • :picses:
  • :plus:
  • :pointup:
  • :potablewater:
  • :purpleheart:
  • :question:
  • :questionwhite:
  • :radiobutton:
  • :recycle:
  • :registered:
  • :sagittarius:
  • :scorpius:
  • :secret:
  • :sixpointedstar:
  • :sleepsymbol:
  • :smallbluediamond:
  • :smallorangediamond:
  • :smallredtriangle:
  • :smallredtriangledown:
  • :soonarrow:
  • :sparkle:
  • :sparkles:
  • :sparklingheart:
  • :squaredab:
  • :squaredcl:
  • :squaredid:
  • :katanasa:
  • :squaredsos:
  • :squaredvs:
  • :star:
  • :taurus:
  • :tm:
  • :tridentemblem:
  • :twohearts:
  • :virgo:
  • :warning:
  • :watercloset:
  • :wavydash:
  • :wheelchair:
  • :whitecheck:
  • :whiteexclamation:
  • :whiteflower:
  • :wlsquare:
  • :blacksunrays:
  • :cloud:
  • :crescentmoon:
  • :earthamericas:
  • :earthasiaaus:
  • :eartheurafr:
  • :firstqmoon:
  • :firstqmoonface:
  • :fullmoon:
  • :fullmoonface:
  • :globemeridians:
  • :lastqmoon:
  • :lastqmoonface:
  • :newmoon:
  • :newmoonface:
  • :sunface:
  • :wancrescent:
  • :wangibbous:
  • :waxcrescent:
  • :waxgibbous:
  • :time10:
  • :time1030:
  • :time11:
  • :time1130:
  • :time12:
  • :time1230:
  • :time1:
  • :time130:
  • :time2:
  • :time230:
  • :time3:
  • :time330:
  • :time4:
  • :time430:
  • :time5:
  • :time530:
  • :time6:
  • :time630:
  • :time7:
  • :time730:
  • :time8:
  • :time830:
  • :time9:
  • :time930:
  • :coupleheart:
  • :dancer:
  • :dancers:
  • :ear:
  • :family:
  • :fist:
  • :girl:
  • :guapimo:
  • :guardsman:
  • :haircut:
  • :hand:
  • :handfist:
  • :handok:
  • :handpointdown:
  • :handpointleft:
  • :handpointright:
  • :handpointup:
  • :handwaving:
  • :clapping:
  • :handsopen:
  • :praying:
  • :headmassage:
  • :infodeskperson:
  • :man:
  • :holdinghands:
  • :menholdinghands:
  • :mouth:
  • :nailpolish:
  • :nogood:
  • :nose:
  • :okay:
  • :oldman:
  • :oldwoman:
  • :personblonde:
  • :personfrowning:
  • :personpouting:
  • :policeofficer:
  • :princess:
  • :raisedhands:
  • :raisinghand:
  • :santa:
  • :thumbsdown:
  • :thumbsup:
  • :tongue:
  • :turban:
  • :woman:
  • :womenholdinghands:
  • :baby:
  • :babyangel:
  • :bowing:
  • :boy:
  • :bride:
  • :constructionworker:
  • :couplekiss:
  • :8ball:
  • :alarmclock:
  • :alien:
  • :anchor:
  • :artpalette:
  • :babybottle:
  • :balloon:
  • :dollar:
  • :euro:
  • :gbp:
  • :yen:
  • :barberpole:
  • :baseball:
  • :basketball:
  • :bath:
  • :bathtub:
  • :battery:
  • :bell:
  • :bellcancel:
  • :bento:
  • :birthdaycake:
  • :blacknib:
  • :blacktelephone:
  • :bluebook:
  • :bomb:
  • :bookmark:
  • :bookmarktab:
  • :books:
  • :bouquet:
  • :bowling:
  • :calendar:
  • :camera:
  • :carpstreamer:
  • :cd:
  • :checkeredflag:
  • :christmastree:
  • :clapperboard:
  • :clipboard:
  • :closedbook:
  • :closedlockkey:
  • :clubs:
  • :confettiball:
  • :construction:
  • :creditcard:
  • :crossedflags:
  • :crown:
  • :crystalball:
  • :darts:
  • :date:
  • :diamondsuit:
  • :door:
  • :droplet:
  • :dvd:
  • :electricplug:
  • :eyes:
  • :fax:
  • :filefolder:
  • :fire:
  • :flagstick:
  • :flashlight:
  • :floppy:
  • :flowercards:
  • :football:
  • :forkknife:
  • :fuelpump:
  • :gamedie:
  • :gemstone:
  • :ghost:
  • :gift:
  • :greenbook:
  • :guitar:
  • :gun:
  • :hammer:
  • :hearnoevil:
  • :heartssuit:
  • :hourglass:
  • :hourglasssand:
  • :inbox:
  • :incomingenvelope:
  • :iphone:
  • :isakayalantern:
  • :jackolantern:
  • :japanesedolls:
  • :japanesegoblin:
  • :japaneseogre:
  • :jokercard:
  • :key:
  • :kiss:
  • :knife:
  • :ledger:
  • :leftmagnify:
  • :lightbulb:
  • :link:
  • :lock:
  • :lockink:
  • :loudspeaker:
  • :loveletter:
  • :mailclosedflaglower:
  • :mailclosedflagup
  • :mailopenflaglower:
  • :mailopenflagup:
  • :megaphone:
  • :memo:
  • :microphone:
  • :microscope:
  • :minidisc:
  • :mobilecalling:
  • :moneybag:
  • :moneywings:
  • :moviecamera:
  • :moyai:
  • :musickeyboard:
  • :mute:
  • :newspaper:
  • :notebook:
  • :notebookdecorative:
  • :nutbolt:
  • :openbook:
  • :openfile:
  • :openlock:
  • :orangebook:
  • :outbox:
  • :package:
  • :pagefaceup:
  • :pagecurl:
  • :pager:
  • :paperclip:
  • :partypooper:
  • :pencil:
  • :performingarts:
  • :personalcomputer:
  • :pill:
  • :pinedecoration:
  • :pileofpoop:
  • :postalhorn:
  • :postbox:
  • :pushpin:
  • :radio:
  • :rightmagnify:
  • :roladex:
  • :rotatinglight:
  • :roundpushpin:
  • :rugby:
  • :satellite:
  • :sax:
  • :scissors:
  • :scroll:
  • :seat:
  • :seenoevil:
  • :shower:
  • :skis:
  • :skull:
  • :slotmachine:
  • :smoking:
  • :soccerball:
  • :spaceinvader:
  • :spades:
  • :speaknoevil:
  • :speaker:
  • :speakerone:
  • :speakerthree:
  • :speechballoon:
  • :straightruler:
  • :sweatdrops:
  • :syringe:
  • :telephonereceiver:
  • :telescope:
  • :television:
  • :tennisball:
  • :thoughtballoon:
  • :ticket:
  • :toilet:
  • :triangularruler:
  • :triangularflag:
  • :trophy:
  • :trumpet:
  • :vhs:
  • :videocamera:
  • :videogame:
  • :violin:
  • :windchime:
  • :wrench:
Top Bottom
