Discuss Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
U
Unused Account 1
Tell me about it! I have a complete bathroom in metros next month:confused:
I just did one 200x75,but vertically,did same procedure battened up then tiled,they were a bit sizy,looked ok but once finished running out when put shower screen ,all youcan do is go with the wall ,
Balloo
I tiled 6 full bathrooms 195mt in a house for a famous mr nesbit . For the golf open .
Total nightmare of a job herringbone on two of them o_O
Myrdaal
No update as to what happened. so i'll throw in...Its almost definitely not British Standard. I work at the building site end of things, and Site managers love to show off their 'knowledge' of BS/NHBC standards. Cutting into the bath has NEVER been an issue. Having said that, they look like the 'metro' type tiles there, and cutting in wouldn't have looked good. That rip looks to be about 10mm at the widest, as Andystiletiling said, your tiler should have changed spacers to absorb it, it would be unnoticeable. Bit late now, but its my opinion dark grouts and white glazed tiles is never a good idea, it just highlights any imperfections, (and those small tiles are always a bit 'sizey') the bevel in the tiles would make it look just as good with white grout. :)
Chelly
Thanks all for your help and the information you have provided me. Received the 1st positive email yesterday from them saying “you have clearly done your research”, offering a refund for the tiling or for the work to be redone.
I notice that most of you hate installing metro tiles, why are they so bad? They responded.....”The specific tiles you have chosen are notoriously problematic and whilst we are happy to reinstall replacements if this is what you decide, we would suggest an alternative tile is chosen to ensure the finish is completed in line with the standards you have quoted and to enable us to complete your bathroom to meet both yours and our expectations”
But I like metro tiles?! Would you advise against also? Not sure I trust them to redo the work, so thinking of getting a quote from a TTA approved tiler (Swansea area), if you know anyone willing to take on my work?
Dumbo
I don't like metros but that is a personal thing many tilers and I mean proper tilers , check their references are capable of producing quality work with metros,.
If you want a tta tiler log on to the tta website I'm sure you will find someone in your area .
Tiles.org.uk
Andy Allen
Any tiler worth there salt should be able to use metros and produce a high standard.
The reason tilers don't like them is because there time consuming, being a small tile, going around and inside windows take forever, and there difficult to grout because of the bevelle.
Personally, I don't mind them, as I tile alot of kitchens, and can't remember the last time I did one that wasn't metros...
Dumbo
Just be aware that nobody comes around from the tta to check the quality of Your work before accepting your membership , also things like checkatrade rely on reviews from customers who maybe can't tell the difference between a good and bad job .
Do your own research ,
On one
Nothing too problematic at all with Metro tiles......just certain setting out criteria to be aware of, which a capable tiler would be aware of.
I would be asking close personal friends for recommendations, not necessarily just via asking on social media sites.
Another reason why metros or any smaller tile is a bad choice within a shower..... the grout joints! Far more grout to discolour. An Epoxy grout is one solution, also a grout sealer but they still do discolour. This is why large format tiles have become popular, also XL format has started to come through.
Tony_C
Go for larger style brick tile and it will help avoid that slither at the top and probably having to start of a half tile, if it has to be wickes replacement tiles they have 300x200 & 400x150 available
Dan
Admin
I think if they're brick fashion you have the old middle of the tile being thicker than the end so against a tile trim it looks terrible unless youve set it out to finish all external corners on 1/4 and 3/4 of the tile. So very limited setting out options width wise.
Thats a pain.
widler
Metros look smart, but they are usually cheap , bent and sizey , I’ve just done 60m2 of them, bit bigger, 30x10cm, Johnson’s very own wicks shi it , bent , curled in at corners and sizey , they can run off a mountain side for all I care :)
Andy Allen
What grout did you use ??....:)
Reply to Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the UK Tiling Forum area at TilersForums.com
Midland Commercial
