- Reaction score
- 7
I recently had my whole ground floor tiled as part of a larger renovation project.
On moving back in I noticed a tile with a crack in it which the contractor said would be replaced.
Over the course of the next two months, a few more tiles developed cracks in them and a few lifted off the floor (assume the https://www.tilersforums.com/forums/tile-adhesive/ failed)
I noticed that pretty much all the tiles have numerous hollow points on them which I know is not indicative of a problem but when they took up the visually impaired tiles, I did notice a remarkable lack of https://www.tilersforums.com/forums/tile-adhesive/ coverage.
They are 900x900 porcelain tiles weighing in at about 18kg each. It is my understanding that these should be laid on a solid bed with as close to 100% https://www.tilersforums.com/forums/tile-adhesive/ coverage. Going by the https://www.tilersforums.com/forums/tile-adhesive/ left on the substrate, it wasn't even 50% on these tiles, and the residue on the large piece of broken tile I'm holding up makes it look like only 25% of that tile was touching any https://www.tilersforums.com/forums/tile-adhesive/. Should these tiles have been back buttered as well?
This explains why those particular tiles had issues but all the other tiles have numerous hollow points. That in conjunction with the obvious gaps under the tiles adjacent to the ones that were taken up make me think most of the tiles were laid in the same way and suffer from the distinct lack of sufficient https://www.tilersforums.com/forums/tile-adhesive/ coverage.
The contractor is saying that because the majority are not showing any issues, that they do not need replacing. They are also trying to say the underfloor heating being turned on too soon and too high caused the problems. This seems to be a red herring as heating has nothing to do with the incorrect application of https://www.tilersforums.com/forums/tile-adhesive/.
Would I be correct in saying that it appears the majority of the tiles have not been laid to a high enough standard and need to be redone?
