I have already successfully tiled my bathroom floor using a fairly cheap manual tile cutter, and a handheld grinder but I did get some minor chipping on my cuts (not an issue as all hidden under the skirting boards). My next task is to tile the shower enclosure where the tile cuts will be visible so I am wondering what is the best way to cut the tiles so that they don't end up having chipped/untidy looking edges? My plan is to use 600 x 300 x 10 porcelain tiles in a centred 'grid' layout. This means I will have to cut all tiles to fit. I will use a trim strip on the exposed edges.
What is my best bet? If this requires a very expensive wet cutter, I might have to get a pro tiler to do this although would prefer to do it myself as I have refurbed the entire bathroom and this is the final job that needs doing!
Grateful for any advice.
