Discuss Suspended Timber Floor Tile Prep in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
you can only reuse the wedges......Ye I know what I bought. Ebay has a lot of junk so is there a better design I should be looking for? Anything similar to this will just have the same problems. Ideally a system that is re-usable given the area I need to work on...
That is because you are doing it wrong and bought the wrong clips.Unfortunately I wont trust those wedge style ones again. Long evening ahead
Fair enough...if you care to expand I would be more than happy to learn!
Too much addy? Not kicking them straight?
Why would a similar design work any better?
Too much https://www.tilersforums.com/forums/tile-adhesive/ around the clips and not breaking them in line with the joint is the usual problem for not breaking off cleanly.
As said before , they are not good clips , probably the worst on the marketTried a different approach with the last 3 rows and every clip snapped properly this time so thanks for this.
I'm still not keen on the U shape though as you can only get it tight to the tile when another tiles weight is on the other side. Leaving overnight left the clips slightly proud so when the next tile went down you couldnt pull it tight.
Reply to Suspended Timber Floor Tile Prep in the Tiling Advice | Tile Forum area at TilersForums.com
