Discuss Sunken grout joint in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
Hey Matt
You can probably do it by grouting as usual then rubbing the grout lines with a dry scouring pad (Blue or white) when the grout is starting to set. Then sponge the joints. it will give you a recessed joint. The client made up a 3D block to do it, which didn’t work, ended up using the side of a washboy sponge to get it
Reply to Sunken grout joint in the Tiling Advice | Tile Forum area at TilersForums.com
