Hi All,
I am currently working on a 270 year old flagstone/sandstone type floor. The property is an old Georgian Farmhouse.
The restoration has gone well so far and we have managed to clean all the old tiles, https://www.tilersforums.com/forums/tile-adhesive/, slc and red lead paint off the floor. I have cut al,l the grout out and last Wednesday I regrouted the floor using a sand and cement grout slightly modified brushed in and then drawn across the joints to bring the water to the surface. All this in an effort to try and stay as close in keeping with the age of the floor. The flags are various sizes ranging from about 600 x 600 up to 1750 x 1200 they are also about 80mm thick. They have approximately a 5mm Grout joint.
My problem is they are of course laid on a earth substrate and I have movement in two of them. Sods law dictates they are two of the largest flags on the floor and they are also right in the main traffic area to boot.
I know they should be lifted and the substrate sorted but this is not an option because of the A. weight involved B. Possible collateral damage I may do to the adjacent flags. C. I have a sample of this stone and after looking at it in cross section I believe if I attempted to lift one it would more than likely crumble/shatter!!!
I recleaned the sand /cement grout out of the two of them last Thursday and then made a neat cement mix which I modified. I then poured that into the grout joints and gently vibrated the flags with a mallet to get it as deep and as much in as possible. I left the floor over the weekend to cure and went over lunchtime today to check. One of the flags has set as solid as a rock but there is still movement in the other larger one.
So that is my dilemma!! Does anyone have any suggestions as to what I could do?
Kev
Kev
