Discuss Setting out - small toilet en suite tiling prep in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
dg-1984
Hi all, please see attached picture of where the toilet is located on the wall that's straight In front of the door. In the picture you can see the centre line drawn on the wall that I was going to have a grout line and use this as my starting point.
My issue is as you can see the toilet is not centered and can not be moved so would I still do what I had thought or is setting out differently a better option.
Thanks.
dg-1984
What size are your tiles? Does it work if you centre the tile on the line?
600x300 tiles and if I centre the tile then I'm left with smaller cuts at the edges.
What's the smallest cut you would consider having at the edge?
WetSaw
As long as it's at least half a tile I'd center the tile rather than grout line, but that's just my personal preference. Also, your choice of tile and grout colour may have an influence.
dg-1984
That seems a very narrow toilet 620 to 640mm?
Toilet is roughly 1090mm wide so if I centre the wall I get 1 full tile and roughly 200 of another each side of the centre.
Depends on tile choice and grout colour. How big are the smaller cuts?
I have one at roughly 65mm on an external corner, tile not patterned and the texture runs the length of the cut, grout will be a sandy colour probably.
Spare Tool
centre back wall 200 cut on each side will wrap round nicely with a 400 cut adjoining it and will centre boxing, if you plan it carefully shouldn't be much waste either..
:thumbsup:
dg-1984
:thumbsup:
Sorry should have said tiles running 300 wide and 600 vertically. So would leave me 100 cut adjoining round the back wall.
Reply to Setting out - small toilet en suite tiling prep in the Canada area at TilersForums.com
Dawz84
