Discuss Self Levelling Compound Over Old Vinyl Adhesive in the Floor Advice - Flooring Forum area at TilersForums.com
K
kiteboy
Reactions
Swansea
Hi all
Ive take up really old vinyl floor tiles that were here when we moved in (in the kitchen) - god knows how long theyve been there.
The tile came up ok but left a glue type substance on the the original tile underneath from when the house was built im guessing
I need to level the floor with a self leveler but not sure what would stick to this hard type glue - its impossible to get off really
We are then planning to tile directly on the levelled floor
I have had a look around of whats out there and it looks like the mapei latex 2 part stuff may do it but wanted to check if theres anything better out there really - we only have a very small utility type room to do and at most we need a depth of about 8mm at one end
Thanks for any advise - first post!
Hi and welcome to the forum Kiteboy. :)
Remove as much of the old black adhesive as you can, by any means possible.
If you have access to a variable speed grinder and grinding cup this will do it.
Then you can use Arditex NA over the top.
Arditex NA
Blunt Tool
Welcome, as above a very good bag and bottle rapid setting latex screed that does not require priming
JordanLincs
Reactions
25
Lincolnshire
Side question- Is the sticky substance underneath from bitumen? To my knowledge this is the adhesive used to lay vinyl tiles?
K
kiteboy
Reactions
Swansea
  • Thread Starter Thread Starter
  • #5
Not - sure its not black stuff - more of an old school brown glue type substance
Reply to Self Levelling Compound Over Old Vinyl Adhesive in the Floor Advice - Flooring Forum area at TilersForums.com
New Threads (Sitewide)
Top Bottom
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
