Discuss Self level or not? in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi everyone. I'm doing a bathroom floor over existing floorboards. I'm also adding a 1.5 sq m electric heating mat before tiling with 30 x 30 granite tiles. I'm applying thermal board which I'm sticking with adhesive. Been told don't need screws or tape as adhesive will do. My dilemma is whether I then self level or just tile directly onto the matting? If I don't level think I will struggle with my levels across the floor. If I do use self leveller first, how do I make sure it doesn't flow through the holes left accessible for pipework coming out of the floor? Should I batten small areas around ? I've used self leveller before but only on ground floor solid floors
Any advice thoroughly welcome. Thanks,
Nick
Hi Dave, if you're there??!!!
Ready to apply self leveller onto thermal insulation board. Heated mat in place. Should I prime the thermal board first or just apply the slc straight?
Final question - hopefully! 30cm square polished granite tiles. Going on top of slc and heated floor. What size notch trowel for this. Would normally go with 12mm aware notch. Too much??
Reply to Self level or not? in the Tiling on Underfloor Heating area at TilersForums.com
Northern Tiler
